disconnect the skip shift?
Old Mar 3, 2007 | 06:08 PM
Dean757's Avatar
Dean757
Default disconnect the skip shift?
I had a 1993 6 speed that I disconnected the skip shift simply by the quick disconnect wire. I now have an 03 6spd. Can I do the same to this car to eliminate unwanted 1 to 4 shifts? Thanks
Old Mar 3, 2007 | 06:27 PM
dpd's Avatar
dpd
not without setting a check engine light.you need to get a skip shift eliminator,it's like $20-25.
Old Mar 3, 2007 | 06:48 PM
87SAM's Avatar
87SAM
From what I understand, a 2.2K ohm resistor will solve the CEL.
Old Mar 3, 2007 | 06:49 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
My 1st and most appreciated mod! Takes 3 minutes and costs under $20. CAGS eliminator.
Old Mar 3, 2007 | 07:19 PM
4BTINGU's Avatar
4BTINGU
If you are going to add some mods and are in need of a tune, have it done then. I had my tuner 'erase' the skip shift after the head cam install. Just a thought....
Old Mar 4, 2007 | 06:48 PM
Dean757's Avatar
Dean757
Default thanks, I will get the cags eliminator
Thanks. Any brand/supplier better than others?
Old Mar 5, 2007 | 05:40 PM
TM-Z06's Avatar
TM-Z06
I have a CAGS eliminator on my desk at home. It's brand-new, and never used (I haven't opened the box). I don't need it. I'll give it to you for $15...shoot me a PM if you're interested.
Old Mar 6, 2007 | 04:51 PM
craig04c5's Avatar
craig04c5
The CAGS is very easy to install.
Old Mar 6, 2007 | 04:56 PM
steve8's Avatar
steve8
Grab the one above for $15. It will be the best $15 you ever spend. Add two minutes to your next oil change and you'll be all set.
Old Mar 6, 2007 | 07:16 PM
FUN LS1's Avatar
FUN LS1
I'm swinging by Orange County Corvettes and West Coast Corvetters sometime this week, I'm buying one then. Maybe my M6 will actually act like a manual and not an A4,
Old Mar 6, 2007 | 08:38 PM
jedblanks's Avatar
jedblanks
I have some 2.2kohm resistors left over from when I did my Trans Am. If I can put my hands on them, I'll send you one for free. I have 3-4 left over. I need to find them so I can do the vette anyway...
To disconnect the skip shift?
