Bumps light up t/control,abs
Old Mar 13, 2007 | 01:57 PM
cliff_ford's Avatar
cliff_ford
Originally Posted by SLOW_POKE
I am a bit confused as to what my actual problem is. Whenever I hit a bump in the road, my service traction, abs, and active handling warnings light up. When I turn the car off the go away, but should i hit a bump in the road or feel the car shimmy while driving they turn back on. I asked the guy that services my car about it and he said it would be $1300+ to fix. I have perused this forum to see if anyone had a more concise answer and what I find are 2 threads running almost similar, but not quite the same, issues. There is this thread that sounds most similar to the problem I am having and another long running thread that details issues almost everyone is having with their EBCM and PBMV (hope I have the acronyms correct). For those of you having the latter issues...are your warning lights always on? The EBCM and PBMV problems seem to be very expensive fixes. Trying to get to the bottom of the issue with the least expense. I'm sure the money I possibly could save could be put to use on some much coveted Mod. I have a 2000 MN6 coupe. Thanks for your helpful replies.
Post the codes you are getting.
Old Mar 13, 2007 | 02:49 PM
SLOW_POKE's Avatar
SLOW_POKE
How do I find the codes? Do I need a special tool/sensor for this? Thanks!
Old Mar 13, 2007 | 02:56 PM
cliff_ford's Avatar
cliff_ford
http://www.stengel.net/diccodes.htm
Old Mar 13, 2007 | 10:38 PM
SLOW_POKE's Avatar
SLOW_POKE
Thanks for the info Cliff. Will check those codes tomorrow and post them.
Old Mar 14, 2007 | 03:57 PM
SLOW_POKE's Avatar
SLOW_POKE
all of the codes that appeared were all followed by H's. I will post the ones that were on there.
TCS:
C1226H - Excessive wheel speed variation
C1243H - BPMV
C1248H - Pump motor stalled
IPC:
B0521H - Tachometer signal malfunction
U1160 - Loss of communication with LDCM
Appreciate all help with these codes. Thanks.
Old Mar 14, 2007 | 04:45 PM
cliff_ford's Avatar
cliff_ford
TCS:
C1243H - BPMV
IPC:
Well if you are lucky the C1226 is the one being caused by the bumps in the road. Have a look at the female connectors at both ends of the passenger side front wheel harness.
Old Mar 14, 2007 | 08:49 PM
SilkOakVette's Avatar
SilkOakVette
Default abs-t/c lights
I had other unrelated codes also. The c1226h(history) is most likley
the problem also causing the other (c) codes. Cliff ford great source
Go for it.
Helped me fix mine,
Tony S
Old Mar 15, 2007 | 08:46 AM
SLOW_POKE's Avatar
SLOW_POKE
Cliff you have been a big help. I cleared my codes yesterday and took her out this morning. Got the usual warning lights.. Checked codes afterwards and only code I got was TCS 1226H. So I will have to check those sensor pins.
I usually fix human bodies and not cars. What is the best way to approach this fiix? Should I try it myself or take it in to a shop? I hate to sound so ignorant, but that's what I am when it comes to auto mechanics.
Old Mar 15, 2007 | 09:50 AM
cliff_ford's Avatar
cliff_ford
Well if you get the wheel off you can do it yourself. If not get your mechanic to replace the harness and the female connector on the body or at least centre up the pins with a scribe.
Old Mar 21, 2007 | 06:16 PM
SilkOakVette
Cammon Doc. anyone wit your educmcation can fixe dis. Go fer it.I
belive In you. U can doo it Solw polk.
Old Mar 21, 2007 | 11:30 PM
SLOW_POKE's Avatar
SLOW_POKE
I plan to give it a shot as soon as I get a floor jack and jack stands!
