Bumps light up t/control,abs
Old Mar 3, 2007 | 10:11 PM
SilkOakVette's Avatar
SilkOakVette
Default Bumps light up t/control,abs
I read up on codes . I've got c1225 and c1226. Now What????
Help!!! On top of this I have a teenage daughter!!!!!!!!!!!!!!!
Old Mar 4, 2007 | 01:19 PM
SilkOakVette
Default abs /tc codes
bump
Old Mar 4, 2007 | 01:26 PM
BlackZ06's Avatar
BlackZ06
Do you have Stainless Steel brake lines on the car .... if so, what brand ?
Can't help with the teenage daughter ... mine just turned 20 and is still a PITA
Old Mar 4, 2007 | 02:02 PM
cliff_ford's Avatar
cliff_ford
Check the female connectors at both ends of the front wheel harnesses.
Old Mar 4, 2007 | 02:28 PM
SilkOakVette
Default abs t/c
I've got an all stock 97 no ss brake linesbut Iguess I'll check connectors
on the front wheels. How do I know if their bad?
Tony
Old Mar 4, 2007 | 03:38 PM
cliff_ford's Avatar
cliff_ford
Tony
The pins are squashed down. PM me your email address and I'll send you a picture.
Old Mar 7, 2007 | 03:54 PM
SilkOakVette
Default Still lighting up
PMed my Email address . Did not recieve any pictures!!!!!!!!!!!
Old Mar 7, 2007 | 03:59 PM
cliff_ford's Avatar
cliff_ford
Did not get the PM. Here you are though.
The connector on the left is new.
Old Mar 7, 2007 | 07:55 PM
SilkOakVette
Default abs-tc codes
Thanks for the picture. Do both ends of these sensors end with the
same jacks and does dealer sell complete assembled and I just unplug,
plug and play.
Thanks again.
Tony S
Old Mar 8, 2007 | 04:33 AM
cliff_ford's Avatar
cliff_ford
plug and play.
Thanks again.
Tony S
The front harness, male one end female the other, is plug and play but there is a female on the body that has to be cut off and replaced. You can try bending the worn contacts back to the correct position with a scribe.
Old Mar 8, 2007 | 08:48 AM
SilkOakVette
Default abs-t/c codes
Thanks Again!!!!!!!!! I'll be pulling front wheels this weekend I
really appreciate your taikng the time to coach me. No other car
has so many dedicated owners that walk the walk.
Fellow AMERICAN OWNER
Tony S.
Old Mar 8, 2007 | 10:54 AM
LF97C5Vette's Avatar
LF97C5Vette
Funny that anytime i have a problem I can guarantee someone else has already had the problem and fixed it...
I also have a '97 w/ Stock braking system, and get the TCS/ABS lights occasionally when i hit a bump... But I only get P1225...
What sensor is that? So i don't have to pull off all my wheels...
Dan
Old Mar 8, 2007 | 12:07 PM
cliff_ford's Avatar
cliff_ford
Dan
That's the driver's side front
Old Mar 8, 2007 | 02:31 PM
SilkOakVette
Lets see if we both can cure lights and codes this weekend.
Looking for Bumps!!!!!!
Tony S
Old Mar 10, 2007 | 05:43 PM
SilkOakVette
Default Victory No Lights Or Codes
I pulled both front wheels and forced all female pins to the middle
of the four jacks than I cleaned them with wd-40.I just got back
from hitting every bump that I knew would trip lights. No lights!!!!!
Thanks for the help!!!!!!
Tony S
Old Mar 10, 2007 | 06:35 PM
Irish Whiskey's Avatar
Irish Whiskey
Have a 30 year old daughter - sorry can't offer you any hope that it gets better - remember, they are in training to become someone's wife.
Old Mar 11, 2007 | 06:37 AM
cliff_ford's Avatar
cliff_ford
Tony S
Well done. Thanks for reporting back, that's the main thing that helps others.
To Bumps light up t/control,abs
Old Mar 11, 2007 | 09:36 PM
1B.DZ's Avatar
1B.DZ
hey guys,
I just searched for this and looks like I found what I need. The only thing I'm missing is the EXACT location of the sensor. I just got done washing and fixing my car this afternoon. Backed it up in the driveway, hit something, and then "Service ABS, TC, & HC soon" warnings. Anybody have any pictures? I'll take a look tomorrow and see if I can find any loose connections.
Sorry: My code was C1225 H C Should be the Left sensor, right(Driver's side)
TIA,
Josh
Old Mar 12, 2007 | 09:10 AM
SilkOakVette
Default abs t/c lights and codes
One jack clips on each front rotor retainer s/b grey in color easy clip
off. Follow wires and you will find same jack clipped into male laying on the frame heldwith push pin. Just pivet pull out , center all female pins
clean with wd40 and reconnect.
Good luck
Tony S
Old Mar 13, 2007 | 01:38 PM
SLOW_POKE's Avatar
SLOW_POKE
I am a bit confused as to what my actual problem is. Whenever I hit a bump in the road, my service traction, abs, and active handling warnings light up. When I turn the car off the go away, but should i hit a bump in the road or feel the car shimmy while driving they turn back on. I asked the guy that services my car about it and he said it would be $1300+ to fix. I have perused this forum to see if anyone had a more concise answer and what I find are 2 threads running almost similar, but not quite the same, issues. There is this thread that sounds most similar to the problem I am having and another long running thread that details issues almost everyone is having with their EBCM and PBMV (hope I have the acronyms correct). For those of you having the latter issues...are your warning lights always on? The EBCM and PBMV problems seem to be very expensive fixes. Trying to get to the bottom of the issue with the least expense. I'm sure the money I possibly could save could be put to use on some much coveted Mod. I have a 2000 MN6 coupe. Thanks for your helpful replies.
