Getting to the front blinker bulb ?
Old Mar 3, 2007 | 11:54 PM
2000Targa Top's Avatar
2000Targa Top
Default Getting to the front blinker bulb ?
My drivers side blinker went out this week, and I haven't researched how to take the clear cover off (or if I even have too) to get to the burnt bulb and replace it with a new bulb. I don't see any screws on the ends of the clear cover. I thought I would check with you guys to help me out.
Old Mar 4, 2007 | 12:20 AM
Dennis Wilson's Avatar
Dennis Wilson
I`ve seen posts where they say you can slip the brake ducting back & reach in through there to get to the bulbs, I haven`t had to do it yet but I hope this helps you.
Old Mar 4, 2007 | 02:46 AM
butch5's Avatar
butch5
3rd Gear
there is a removable panel in the inner fender linner that gives access to the turn signel
Old Mar 4, 2007 | 02:50 AM
DeeGee's Avatar
DeeGee
You'll get three suggestions
Go in through the brake ducts - not easy with a Z06 or if you have screens
Go in through the bottom by taking out the bottom panel
The one that works for me is:
Turn on the headlights and back off one position to kill the lights.
Unscrew the 3 small screws on the black plastic housing around the headlight. Gently pull the housing clear. Reach down around the headlight unit and release the bulb holder. It unscrews counter clockwise but it has a plastic clip which you need to squeeze to release it. Change the bulb. Reseat the bulb holder and turn until it clicks back in place. Put the plastic housing back in place making sure to locate the small plastic tab in the bracket on the headlamp cover. Replace the 3 screws and close the lights.
10 minute job.
The bulb is a 4157NA
Old Mar 4, 2007 | 01:29 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
Old Mar 4, 2007 | 10:31 PM
FRC Rob's Avatar
FRC Rob
Agree with DeeGee; the headlight method is easy. Unless you've got skinny arms, it is also helpful to unscrew the hood stop...that gives you more clearance to get in there.
Old Mar 5, 2007 | 12:59 AM
electronbluec5's Avatar
electronbluec5
10 minute job.
Good Info!!
To Getting to the front blinker bulb ?
