Forged Crank Pinning
Old Mar 5, 2007 | 06:29 PM
ICUALL's Avatar
ICUALL
Default Forged Crank Pinning
Anyone Pinned a Eagle 4340 Forged Crank ? Trying to do mine using the Crank Pinning Tool and cannot seem to make a dent in Drilling it. Any Suggestions, idea's etc. or am I wasting my time and effort ???
Old Mar 5, 2007 | 06:37 PM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
I have drilled through my billit crank. Make sure you use a quality drill bit. I went and bought a nice DeWalt metal bit. Made quick work of it.
You can drill it, just takes a good bit
Old Mar 5, 2007 | 06:38 PM
FRCTony's Avatar
FRCTony
Might want to consider getting it milled for a key.
Old Mar 8, 2007 | 09:56 PM
ICUALL's Avatar
ICUALL
Default It's Pinned
Well, the purchase of a carbide steel bit and using a "slow drill" I was able to get the hole drilled in the Crank and a pin installed ! Patience was the key used a 18 Volt Cordless Drill at low speed !
Old Mar 9, 2007 | 09:53 AM
94legaleagle's Avatar
94legaleagle
metal cutting fluid like "Mystic Metal Mover" (yellow can w/ blue lettering) will help lots also - when drilling, generously squirt the Mystic onto the drill bit - NEVER allow the drill bit to get hot or even warm - if it does, you are not using enough cutting fluid
Old Mar 9, 2007 | 12:01 PM
Julian@Cartek's Avatar
Julian@Cartek
Old Mar 9, 2007 | 12:32 PM
kromberg's Avatar
kromberg
You spell WD40 very strange
Keith
Old Mar 9, 2007 | 07:29 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Is it possible to drill without using the crank pinning tool?..........Paul
Old Mar 9, 2007 | 08:19 PM
leo12's Avatar
leo12
Go to you hardware store and ask for a COBALT DRILL BIT..it will go throu the forged shaft like butter..nothing alse will cut it.............
Old Mar 9, 2007 | 08:22 PM
leo12's Avatar
leo12
It will take about two secs to make the hole
Old Mar 9, 2007 | 10:14 PM
drivinhard's Avatar
drivinhard
CRC makes a nice can of spray cutting fluid that you can usually find pretty easy locally.
Old Mar 10, 2007 | 01:32 PM
94legaleagle
Keith
LMAO Yeah, I know WD40 is the standby substitute for everything, including drilling/cutting fluid, but MMM in the yellow can really does work better.
Old Mar 10, 2007 | 07:59 PM
yankeevetteconvert's Avatar
yankeevetteconvert
I have a ASP pulley. Who sells a pinning kit for it?
Old Mar 11, 2007 | 12:07 AM
drivinhard's Avatar
drivinhard
I've got an SLP UD pulley (has a 3/16 keyway) and I bought/used the ATI LS1 pin kit for that. Put the fixture on, drill the hole, ream it, stick the 3/16 pin in. Takes just a few mins.
Does the ASP have a (3/16) keyway?
Old Mar 11, 2007 | 09:42 AM
molson's Avatar
molson
I just got one from A&A corvette.
To Forged Crank Pinning
