Go to the Weiand LSx intake site in the installation instructions they list the size and lenght. I don't remember off the top of my head, but I thought they were 90 or 95 mm.
Thanks. Reason I am asking is I just bought a FAST and they are 110mm long, but are plain carbon steel. ARP makes a nice set, but I was afraid they may be too short for the FAST.
Stock long bolts are fine, use of the button heads on the valley is critical.
The torque is relatively light for the bolts with the FAST. As you know by now many FAST problems relate to over torquing.
I don't remember and car is in storage, don't the stock bolts bear up against the plastic directly? I know the FAST bolts use a DIN 7349 heavy washer under the bolt head to distribute the load to the upper shell.
Sock bolts are 4.5" long and have a normal thickness captive washer which does bear on the plastic lug. Stock torque is only 90 in/lbs.
