Help! Installed C6 Z06 shifter incorrectly
Old Mar 7, 2007 | 08:52 PM
attyman1968's Avatar
attyman1968
Default Help! Installed C6 Z06 shifter incorrectly
I just installed a C6 Z06 shifter in my 01Z. However, something is wrong and I want to know what before I take off the console. When I place it in gear, I can push the shifter side to side. I discovered this when I could not get into 1st. I had to push the shifter to the far right in neutral then gently come back to the left to get into 1st. I had to do just the opposit to get into reverse. I know I tightened everything up including the bolt....? I appreciate any help.
Old Mar 7, 2007 | 09:15 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
you may have installed the bottom of the shifter out of the pocket(not sure if this is possible)
most likely, the shifter base is out of alignment, ck out the stock shifter, see that 'L' shaped pin, use that in the hole up front to align
edit: more info, if you can't slide the pin in, loosen the 2 torx bolts, also notice the wear marks from the bolts on the oe base
Old Mar 8, 2007 | 07:38 AM
cenzo's Avatar
cenzo
The bolt that clamps the shifter to the shift rod isn't tightened properly. Check it again. Trust me.
Old Mar 19, 2007 | 05:26 PM
vettenuts's Avatar
vettenuts
Did you replace the entire assembly?
Old Mar 19, 2007 | 06:20 PM
Phat Ride's Avatar
Phat Ride
You don't have it aligned properly, I did the same thing. Play with the alignment of the unit and put into gear to verify your shift pattern before tightening down all your bolts.
To Help! Installed C6 Z06 shifter incorrectly
