Ramps
Old Mar 7, 2007 | 10:30 PM
crashco's Avatar
crashco
Navigator
Default Ramps
I just found this.
http://www.mustangworld.com/ourpics/...amps/index.htm
Anyone try this approach to ramps? Looks like a cheap way to get your C5 up in the air!
Good: cheap, ease your way up - also nice if you back onto them, should NOT slide and you can track your progress up by counting the bumps at each layer
Bad: could have issues as you hit each layer, but a simple angled end should take care of this, Vette might not like going where a "stang has been?!?!?!
I was thinking of adding wheels at the tall end of each and a handle off to the side of the low end. Then ya just grab the handle, lift until wheels hit the ground, and drag or push them out of the way.
Old Mar 7, 2007 | 10:48 PM
jeanlucpicard's Avatar
jeanlucpicard
For one thing, a Mustang - even lowered like my son's 2002 GT, does not need a ramp to climb up for changing oil. Next, wayyyyyy toooo muuccchhhhh ramp for a Mustang let alone a Vette. Lastly, too much trailer park, not enough Vette ambiance.
There are a lot of better options out there than building a set of wooden ramps as long as I am tall and weighing about as much. I'll pass.
Old Mar 7, 2007 | 10:51 PM
crashco's Avatar
crashco
Navigator
Default Trailer Park
Maybe ya build it out of oak - or walnut. Nice sand job, stain and shiny final coat - looks like a real Vete owners masterpiece!
And if we have a real cold winter, you have a start on building a fire to keep warm.
Old Mar 7, 2007 | 10:57 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
hey lc, you been in the woodlands tooooo long. come over to the other side of i-45, we use ramps over here. position the car on them to get the lift under the car easier, and use them under the car ramps to get it on the trailer without dragging the bottom. not in use, just stack them against the wall or put them up on the handy-dandy shelves i built to store tires, wheels and other parts you don't want taking up floor space.
Old Mar 7, 2007 | 11:01 PM
jeanlucpicard
That's why I own aluminum hydraulic jacks with less than 2-1/2" clearance for my lowered vert. My Elite aluminum rocker savers with built-in pucks complete the package. No ramps necessary to scuff my shiny garage floor.
Old Mar 8, 2007 | 12:10 AM
BitViper's Avatar
BitViper
Huh....I thought it was a pretty good Idea
Old Mar 8, 2007 | 12:35 AM
casisthefirst's Avatar
casisthefirst
thats the ghettoest ramp I ever seen, although I admire the measurements sketch of the ramp
Old Mar 8, 2007 | 01:15 AM
dudleyd's Avatar
dudleyd
Get a pair of Rhino Ramps from Pep Boys, probably cheaper then the cost of lumber to build those.
Old Mar 8, 2007 | 07:10 AM
BrianG01's Avatar
BrianG01
http://www.harborfreight.com/cpi/cta...emnumber=91039
will that jack work on our cars? I wasnt sure what kind of minimum height and reach it had to have to reach the right spots.
It seems to have a rubber pad on the arm, would I still need the safety pucks?
Old Mar 8, 2007 | 07:52 AM
berryj's Avatar
berryj
Actually, I've seen that same ramp posted on the forum w/ a vette on it. A guy on the forum made it for his car.
Old Mar 8, 2007 | 09:35 AM
87SAM's Avatar
87SAM
I made some ramps very similar to those (shorter) a few years ago for the C4 and they also work great on the C5. I also drilled holes on the floor so I can pin them in place to prevent them from scooting around on the smooth floor. Made them out of 2X10’s. Great for oil changes. Would keep them over Rhino ramps any day. As mentioned, tracking your progress up each step is a nice feature.
Old Mar 8, 2007 | 11:06 AM
DPG's Avatar
DPG
St. Jude Donor '06
whats wrong with the wooden ramps. it's a tool, not a hood ornament. A couple people here have made wooden ramps here and they work great.
Old Mar 8, 2007 | 11:09 AM
HollywoodFRC's Avatar
HollywoodFRC
Default EG's Design?
Looks like they 'borrowed' forum member EG's ramp design. I built these same ramps last summer and they work great. They are, however, very heavy and bulky.
Old Mar 8, 2007 | 11:52 AM
Mike Mercury's Avatar
Mike Mercury
http://mikemercury.home.att.net/ramp.htm
To Ramps
