dash lights
Old Mar 9, 2007 | 04:41 AM
shulamite's Avatar
shulamite
Default dash lights
how does one change , burned out dash light, in c5's?
Old Mar 9, 2007 | 12:26 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You need to specify if you are speaking about the radio/hvac controller or the DIC itself. The radio and hvac controller, the bulbs will burn out with old age and need replacing with a source of 70ma bulbs and a soldering iron. The DIC has indicators that use standard lamps, I think 194's back there, however, the background illumination is a whole different matter using the high-voltage unit on the rear of the cluster as well as special tube lights on the two sides. GM doesn't sell those by themselves. You have to replace the whole cluster or find another cluster to remove the parts from. Changing out the cluster causes a a legal issue with the mileage.
Old Mar 9, 2007 | 03:31 PM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Which lights specifically, I've replaced or removed each and every light on the inside of these things... be a little more specific and we'll fix ya up!
Old Mar 15, 2007 | 06:12 AM
shulamite's Avatar
shulamite
Default check engine light needs to be replaced
ck eng light needs replacing
To dash lights
