TAC Module WHERE, WHY & HOW? Please help
Old Mar 9, 2007 | 12:24 PM
Freddy_97_C5's Avatar
Freddy_97_C5
Default TAC Module WHERE, WHY & HOW? Please help
I just spent 400.00 at the dealership to replace the Throttle Positon Sensor because I had Reduce Engine Power and Service traction control system. They told me the problem was fixed a week later smae proble they said I had a bad battery cable but, I can read codes just as well as they can and I am getting CODE P1518 Tac module.
The 97 C5 is running good now except for engine light should I replace the TAC module? Where do I find one? How do I replace it and where is it located?
Old Mar 9, 2007 | 12:27 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
GM repair are often warr., talk to the serv. manager first
the tac mod. is piggybacked onto the pcm down on the pass. side frame rail
take a look at the wiring on the fuel rail crash bracket(aft LHS intake) for wire chaffing
it's most likely the tac mod., they often fail in the 97/8 cars
Bill Curlee has firsthand experience with this
Old Mar 9, 2007 | 12:47 PM
vettenuts's Avatar
vettenuts
Yep, have a friend whose failed two days before the 2003 Caravan.
To TAC Module WHERE, WHY & HOW? Please help
