Fuel pump flow rate???
Old Mar 10, 2007 | 01:25 AM
split63's Avatar
split63
Default Fuel pump flow rate???
Does anyone know what the required fuel pump flow rate is for the LS1 @ WOT?
This would be the flow rate @ 60 PSI.
Thanks,
Old Mar 10, 2007 | 01:46 PM
split63's Avatar
split63
The reason I ask is that I'm putting an LS1 in an older vette and I need to get an external fuel pump and I want to be sure it has enough fuel flow such that the pressure does not fall under Wide open throttle.
I'm currently looking at this one http://www.msdignition.com/fuel_7.htm
and I have not reason yet to believe it would not be sufficient, as I have no info on the required fuel rate. This one claims to support 500HP which would tend to indicate that it should be ok for a 350HP LS1. But it can be hazardous to trust such claims.
Also, does anyone know what the inside diameter of the fuel line is on 2000 and later models? That is the fuel line from the regulator near the tank to the fuel rail on the engine.
Thanks,
Old Mar 10, 2007 | 10:50 PM
CODE4LS1's Avatar
CODE4LS1
It flows over 255 lph, stock I believe is 190 lph, so I think youre fine
Old Mar 10, 2007 | 10:55 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
Thanks,
If you can get an intank pump I would recommend it. That pump is pretty cheap but you can also get an actual Walbro 255 lph pump too. The line you will want to use is just -6 line, or 3/8"
If you want a larger Bosch pump, I can get you one for about $300. These are the 044 pumps and will be more than enough for you.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Mar 10, 2007 | 11:01 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
a vette tech told me to install a mustang pump and then to use ls1 edit to reduce the injector cycle time to compensate for the increase of pressure in the lower rpms and idle
To Fuel pump flow rate???
