Please help! E-Brake not working!
Old Mar 10, 2007 | 02:08 PM
Minmey15's Avatar
Minmey15
2nd Gear
Default Please help! E-Brake not working!
Hello everyone! I have 2000 Coupe. My emergency brake does not work properly. If I pull it as hard as I could, it some what works, but if where I park has some slope, then it doesn't. I had a dealer adjusted the brake, and according to the dealer, they adjusted it as much as they can. But just the other day, I was at a gas station, and my C5 started to roll!! Is it common? Is there anything I can do? If anyone can give me advices, I would greatly appreciate it. Thank you.
Old Mar 10, 2007 | 02:25 PM
jmliles's Avatar
jmliles
Are you leaving it in gear? I can't imagine a gas station would be on a large enough slope for it to roll while parked in 1st or reverse in combination with whatever amount of pressure your hand brake is applying.
Old Mar 10, 2007 | 02:32 PM
pubin's Avatar
pubin
Mine does the same thing, and odly enough it seems when it is cold the e break catches better. Also, sometimes the ebreak wont even grab at all, it will jsut lose tension and then randomly, later it will start working again *shrug*.
Old Mar 10, 2007 | 03:44 PM
McQuickster's Avatar
McQuickster
Mine does the exact same thing. I bought my car used. I adjusted it all the way and it still doesnt catch very well. I took off the rear rotors, and the inside where the ebrake works was worn down and had a ridge worn into it. The ebrake shoes were also worn down very much so. I havent put on new ebrake shoes or rotors, but I assume this will solve the problem. Seems like people are driving with the ebrake on or something. Or they were overtightened. Who knows.
Old Mar 10, 2007 | 07:16 PM
Setpoint's Avatar
Setpoint
The C5 e-brakes are poorly designed. Mine never worked correctly, and I purchased my 2000 new. I never brought it back to the dealer for adjustment, because I am scared to death of them. The forum was full of owners complaining about the e-brake. That and the column lock were the major complaints.
Old Mar 11, 2007 | 03:05 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Yes it's very common, they were never adjusted correctly at the factory, it isn't really a design flaw at all. Do a search in here for E-Brake adjustment. If you come up empty, shoot me a PM and I'll fix you up...
Old Mar 11, 2007 | 03:12 AM
Minmey15's Avatar
Minmey15
2nd Gear
Thank you everyone! I wasn't sure if it's a common problem or if mine was a special case. I do leave it in 1st gear now days, and avoid parking on hills. I feel some what relieved that I'm not the only one who's got this problem...
Old Mar 11, 2007 | 03:18 AM
jdmvette's Avatar
jdmvette
Night Owl for life
adjust your little star adjuster-thingie to expand enough so that when you pull up the e-brake handle, it fully locks at 45 degrees. make sure you don't adjust too much and bind the rotors, though.
don't know what the star adjuster-thingie is?
use a flathead screwdriver and a hammer.
Old Mar 11, 2007 | 03:46 AM
tstar's Avatar
tstar
Adjust so that it's a bit tight putting the rotor back on. Get eveerything put back together and drive 5mph in reverse and pull up on the E-Brake handle to adjust the shoes. If that doesn't work, you'll probably have to look at the pawl under your E-Brake handle...
Did that make sense? I know my head is still spinning from the "star adjuster-thingie"
Old Mar 11, 2007 | 05:16 AM
jdmvette's Avatar
jdmvette
Night Owl for life
it's not very technical, but hey, it works!
Old Mar 11, 2007 | 05:18 AM
tstar's Avatar
tstar
Truth be told... that's the same thing I call it! shhhhhhhhh
Old Mar 11, 2007 | 09:11 AM
rws.1's Avatar
rws.1
here's a recent thread.
the member website cited within my post in that linked thread provides a couple different fixes depending on your problem...
http://forums.corvetteforum.com/show....php?t=1619753
To Please help! E-Brake not working!
