NOS Question
Old Mar 17, 2007 | 12:16 AM
TylerZ06's Avatar
TylerZ06
Default NOS Question
Hey guys I bought a NX wet kit a few years back that I put on my Camaro from a friend and the main feed line from the bottle is 2 separate short lines with a connector in the middle making it the same length as one that would come new in a kit. Is there anything I can do to totally seal that line to where it could never leak? The connector in the line would be in the cars cabin. Or do you think Teflon tape would be trust worthy? Soldered maybe? I just want to be safe. The kit came off my camaro do you think I am going to have a problem using the nitrous solenoid. I don’t not have the fuel solenoid anymore for it was a wet kit. Can I just use the fuel solenoid and make it a dry kit? One last thing I bought a nitrous gauge
4128: Autometer Lunar Nitrous Pressure Gauges
Specs: 2 1/16th inch - NITROUS PRESS, 0 - 1600 PSI -
I am going to put it in the pillar in the car and the nitrous has a pressure line going to it that would be in the car. It says nothing about the gauge not supposed to be in the car. Does anyone know if this is a no no? Thanks guys I knew I could count on you!!
