Ignition Key
Old Mar 17, 2007 | 02:58 PM
ant21b's Avatar
ant21b
Default Ignition Key
I need to have a resistor ignition Key made how can this be done other than going to the dealer. Thank You
Old Mar 17, 2007 | 03:03 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
As far as I know the dealer is the only one who can do it.
I just replaced and ignition cylinder and didn't have any keys to begin with, I took my new ignition cylinder to a locksmith and was told GM does not give out the codes to cut keys to anyone but their dealerships.
Old Mar 17, 2007 | 03:31 PM
87SAM's Avatar
87SAM
I have purchased them at a locksmiths shop before for my C4 (They also have the resistor). Don't know why a C5 would be different.
Old Mar 17, 2007 | 03:49 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Ace hardware had them, you just need to know what number key you need.
Old Mar 17, 2007 | 04:08 PM
white90conv's Avatar
white90conv
I recently got a C5 key cut at a local locksmith and he also measured to get the correct resistor pellet. Cost about $25, took about 5 minutes. The head of the key was a bit smaller than the OEM key.
Old Mar 17, 2007 | 04:59 PM
ALLEGRO's Avatar
ALLEGRO
When I recieved my "Corvett Key" fob I took it to a local dealer and they cut it for FREE.........that's unusual.
Good Luck
Old Mar 17, 2007 | 09:19 PM
corvettedoug's Avatar
corvettedoug
I paid 7 bucks for mine on ebay. Do a search for VATS key and just make sure you get a doublesided vat key. The older GM vechiles used the 1 sided.
Just test the resistance on your existing key and use the key chart on the sellers post and pick the right key. Then you can take it to any locksmith that can make a copy for about a buck.
The seller's ebay id is locksmithsource.
Old Mar 17, 2007 | 09:30 PM
chris308's Avatar
chris308
bought my key from Ecklers, i needed other things as well. Just used my ohm meter to measure what pellet i had, then used the chart on ecklers site. Just need to get it cut now.
Old Mar 21, 2007 | 02:11 PM
bighank's Avatar
bighank
Default New Key
Go to fleebay after you find your resistor pellet value. Search forum for the chart relating resistance value to key number. About $6 or $8 for A DOUBLE SIDED VATS KEY BLANK. Then call around. I found a local locksmith to cut it for only $1. Dealer wants a FORTUNE. BIGHANK
Old Mar 21, 2007 | 02:29 PM
rws.1's Avatar
rws.1
measure the resistance of the pellet on your current key. determine what the VATS # is..
order that number key form this place
http://search.stores.ebay.com/Locksm...382269QQsofpZ0
get it cut where you want....
Old May 10, 2007 | 03:31 PM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
9.532 = #14
lost a key and need to replace it .................
Old May 10, 2007 | 03:55 PM
rws.1's Avatar
rws.1
here a link to a VATS table
http://forums.corvetteforum.com/show...ght=VATS+codes
generally it is the closest VATS number that is over the measured resitance but given that difference is 2
I would go with #14
To Ignition Key
