fuel tank question
Old Mar 19, 2007 | 06:12 AM
1a-play's Avatar
1a-play
Default fuel tank question
how does fuel make it from the passenger tank to the driver side where the pump is located? thanks for any help
Old Mar 19, 2007 | 06:38 AM
Blown 346's Avatar
Blown 346
Passenger tank?
Old Mar 19, 2007 | 06:54 AM
1a-play's Avatar
1a-play
the tanks are split
Old Mar 19, 2007 | 09:02 AM
bluewire's Avatar
bluewire
Active Streak: 90 Days
There is a venturi pump that transfers fuel between the tanks.
Old Mar 19, 2007 | 09:13 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Old Mar 19, 2007 | 11:05 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
The venturi pump info is correct -- it is driven off fuel/pressure that is teed from the main fuel pump feed that goes to your fuel rails. In addition under normal operating conditions, the passenger side tank is drained first completely before the driver tank is drained. So when you are at 1/2 tank of gas on the DIC, that means your driver tank is full and your passenger tank is empty.
Old Mar 19, 2007 | 12:24 PM
1a-play's Avatar
1a-play
thanks for the info
Old Mar 19, 2007 | 08:18 PM
T VETTE's Avatar
T VETTE
Yes, tanks alot.
To fuel tank question
