Help can any one help (Battery)
Old Mar 19, 2007 | 09:47 AM
golf1231's Avatar
golf1231
Default Help can any one help (Battery)
Hello I have a 02 vert and the battery keeps dieing on me. About every 30 days or so i have to put a charger on it to bring it back. Can any on tell me about this, or is this something that happens to all vettes. Please help
Old Mar 19, 2007 | 10:04 AM
tellefan's Avatar
tellefan
Is it the original battery?? if so check and see if it is leaking. That's a common, very expensive problem. If you're gonna buy a new one look at remybattery.com. I bought a Excide Orbital battery, NTB and Napa auto parts also sell them but at a higher price.
I've stayed away from Optima red top batterys, it seems to be a hit or miss type of thing. Many problems with the Optima. You can do a search on the Forum. Hope this helps. David
PS Buy a battery tender and use it when in storage.
Old Mar 19, 2007 | 09:13 PM
golf1231's Avatar
golf1231
Default Help battery
the battery only goes dead if i leave the car sit for a while. is this common?
Old Mar 19, 2007 | 10:51 PM
Silvervettes's Avatar
Silvervettes
St. Jude Donor '07
Try asking your question on C5 Tech. There are guys who have lots of valuable experience that monitor that site on a regular basis.
Do a search on that site by clicking on search and type in battery and maybe you will find the answer to your question before you ask.
Old Mar 20, 2007 | 05:52 AM
jkj's Avatar
jkj
Very expensive? Excuse my ignorance but why would this be expensive?
Old Mar 20, 2007 | 08:12 AM
pearsonhaus's Avatar
pearsonhaus
I believe your Corvette manual tells you NOT to let the car sit for more than 25 days without running it because it can pull the battery down. I started my car yesterday as it has been over two weeks since it was driven for that reason. I have had no problem with the battery by taking their advice. Wishing you the very best...
Old Mar 20, 2007 | 08:54 AM
golf1231's Avatar
golf1231
Default Thanks for the help
Thanks for all the help.
Old Mar 20, 2007 | 11:16 AM
04cad's Avatar
04cad
St. Jude Donor '07-'08
Default Vette battery going dead in 30 days
Also check to make sure anything that might have a light on when opened is closed all the way. I had a similar problem on my 92 and finally figured out I was leaving the console slightly open which evidently allowed the console light to be on and undetectable and that was doing it over a long down period. I made sure the console was all the way closed and the problem stopped for me.
Old Mar 21, 2007 | 11:16 AM
smithd7's Avatar
smithd7
Try running an onboard charger, maintainer.I've had one in my'99 since new,still have original batt.
Old Mar 21, 2007 | 06:02 PM
grove's Avatar
grove
Default battery
Its your remote control for your alarm system. It is constantly drawing from your batter while you store it. Just start it a couple times a month a let it run for about 10 minutes and that will solve your problem.
To Help can any one help (Battery)
