air conditioner
Old Mar 20, 2007 | 07:25 PM
tngerman1999's Avatar
tngerman1999
Default air conditioner
tried out my air for first time today since purchase , passenger side blows cold but drivers side remains warm any help would be appreciated
Old Mar 21, 2007 | 05:46 AM
Blown 346's Avatar
Blown 346
Id like to know as well, My truck does that on occasion. I tried to fill it and the kit I used said to service A/C system.
Old Mar 21, 2007 | 07:17 AM
nastymant's Avatar
nastymant
This is a common problem..Check the codes; Do you have any codes like B0361 or B0441? Also do a search for those on here...there are numerous threads on this problem...It could be an actuator (most likely) or controller problem if your freon charge is correct.
Old Mar 21, 2007 | 06:06 PM
SilkOakVette's Avatar
SilkOakVette
Default a/c half cold
I had the same problem last summer with my 97. It was low 134a. Once I topped it off it was cold on both sides.
Tony S
Old Mar 21, 2007 | 06:29 PM
hotwheels57's Avatar
hotwheels57
It's a dual zone a/c system isn't it? Maybe, you just need to adjust the drivers side temperature control ****?
Old Mar 21, 2007 | 06:39 PM
kevin40zx's Avatar
kevin40zx
Lot of this going around. I guess cause it spring. Found a good thread and its at the top right now.
Thread title: reindexing hvac actuators
To air conditioner
