Bolt Torques - Torque Tube / Prop Shaft
Old Mar 19, 2007 | 11:45 AM
leonardj's Avatar
leonardj
Default Bolt Torques - Torque Tube / Prop Shaft
I'm rebuilding an 01 drivetrain w/ an M6 trans. Did a quick search, but didn't see anything about bolt torques. Can anyone help me out? I'm looking for the following assembly bolt torques:
M10 (mm) bolts: TT to Trans, TT to Bell Housing, Bell Housing to Engine
M12 (mm) bolts: Prop Shaft Flex Couplings
Old Mar 19, 2007 | 07:36 PM
Patches's Avatar
Patches
Here are the C5 torque values you can download from my website.
http://www.redshift.homestead.com/files/C5torque.PDF
Old Mar 20, 2007 | 08:17 AM
davidfarmer's Avatar
davidfarmer
which was taken from one of my websites...
which I copy/pasted from the GM Service Website
more good info at http://www.davidfarmerstuff.com
Old Mar 23, 2007 | 11:56 AM
leonardj's Avatar
leonardj
Thank you gentlemen!
Do you know what year this is for? I only ask b/c I believe the prop shaft bolts went from 10mm to 12mm in '01, & didn't know which one the 52 ft-lb torque (coupling) was for. Did I miss the bellhousing bolt torques? Is the "driveline sup tube" the torque tube?
I apologize for all the ?'s. I guess I'm stuggling with what the list calls the components & what I know them as.
P.S. - Patches, I'm in Noblesville, IN. I have a coworker from Floyd ****.
To Bolt Torques - Torque Tube / Prop Shaft
