cam is installed.....question though?
Old Mar 19, 2007 | 06:47 PM
2001blkvet's Avatar
2001blkvet
Default cam is installed.....question though?
just got my car back from vet drs. i have jba l/t headers, varram, bbk80mmm t/b underdrive pulleys, and just installed tsp 228r 114lsa cam.
dynoed 349... hp
337 trq
is this low, its on an 01 auto
Old Mar 19, 2007 | 07:10 PM
happa's Avatar
happa
maybe, but autos are not good on the dyno. They dont put down good numbers, unless you had some other work done. Get a good stall and that will help you on the track or street. Good Luck!
Old Mar 19, 2007 | 07:23 PM
gojo's Avatar
gojo
dynoed 349... hp
337 trq
Those are pretty good #'s. You will never be happy because of all the dyno queens on the Forums. As Happa said get a stall and add some gears and you will leave the rest in the dust.
Old Mar 19, 2007 | 07:26 PM
vettenuts's Avatar
vettenuts
Do you know if the converter was locked when they did the pull on the dyno?
Old Mar 19, 2007 | 07:34 PM
2001blkvet's Avatar
2001blkvet
what would be a good reccomendation on gears and stall? i believe i have the 3.15 now. would it make more sense to go with heads rather than gears?
Old Mar 19, 2007 | 07:47 PM
gojo's Avatar
gojo
It was likely locked or the TQ would have been higher than the HP.
Gears and converter will give you better results than just heads. 3.42's and an SS3600 would be a nice driveable combo if that's a priority.
To cam is installed.....question though?
