NEED alignment after lowering?
Old Mar 19, 2007 | 07:45 PM
gsxr150's Avatar
gsxr150
Default NEED alignment after lowering?
So...do you need to align after lowering, or is it fine as is? I've heard both, and now not sure what to think.
Old Mar 19, 2007 | 08:01 PM
Watchful's Avatar
Watchful
From: An Englishman drinking his way through Tewksbury MA
St. Jude Donor '09
Needs aligning! I've never heard that you wouldn't need aligning.
Old Mar 19, 2007 | 09:06 PM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
You definitely want to align it.
Old Mar 19, 2007 | 09:19 PM
gpracer1's Avatar
gpracer1
I didnt align mine, and it cost me.
I could show you a pic of my left front tire that is wasted on the inside after lowering.......if you want me too.
Old Mar 19, 2007 | 09:31 PM
BQuicksilver
Same exact issue here. I learned the hard way and waited 3 months to align...then it wouldn't drive straight when aligned. Why? One of the tires was completely worn on the inside from lowering without an alignment.
Old Mar 19, 2007 | 10:31 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
A alignment is a good thing to have done. I finally lowered mine and will be getting it aligned shortly to make sure there are no problems.
Old Mar 20, 2007 | 12:23 AM
gsxr150's Avatar
gsxr150
What do they get for a basic alignment?
Old Mar 20, 2007 | 12:29 AM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
I paid $88 including taxes for a 4 wheel computer alignment at my NJ National Tire & Battery. I believe they're a National chain.
Old Mar 20, 2007 | 11:50 AM
hotwheels57's Avatar
hotwheels57
The local Chevy dealership is getting $79.95 for a four wheel alignment on Corvettes. I commented to the service manager that many Corvette owners are lowering their cars and getting the alignments. He said his techs would do the lowering on stock bolts, no bushings cut, and still charge only $79.95. You might check with your local dealerships...
Old Mar 20, 2007 | 12:31 PM
davidfarmer's Avatar
davidfarmer
you should check the toe. Use my DIY guide to easily check your toe at home. You want it around 0 or slightly (1/32") in or out. If it is much more either way, just adjust each tie rod end to compensate
http://www.davidfarmerstuff.com/
To NEED alignment after lowering?
