G5X3 cam is installed...
Mar 20, 2007 | 10:53 AM
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
where do I set my rev limiter.
Where does the cam stop making hp?
Mar 20, 2007 | 11:02 AM
I don't rev mine past 6500, others (Z06) go higher.
Edit: I see you have a Z, sorry can't help you there.
Mar 20, 2007 | 01:48 PM
Pretty sure with proper intake and exhaust the G5X3 is a 6500-6700rpm cam. Some people wind to 7k but that's a bit of over-rev in my opinion.
Mar 20, 2007 | 02:53 PM
6700-7000rpm, depending on gear/transmission/intake/valve float.......
Great choice on the cam, we love that one.
Mar 20, 2007 | 05:49 PM
Quote:
Originally Posted by
Vette Ed
If you have the valve train to support it I'd spin that baby to 6,800 easy.
Mar 20, 2007 | 09:06 PM
Vette Ed
you WILL either get thee to a dyno tuner and have a REAL tune or you will never run right with a cam mod. That's "period"
Mar 20, 2007 | 09:54 PM
vetred
You need to get the car tuned after the cam install, to truely maximize power gains.
Mar 20, 2007 | 10:36 PM
Thanks guys!!!
Mar 21, 2007 | 12:43 AM
I installed the G5X3 112 lsa cam recently and it will make power up to about 6800 rpm depending on your mods. I set my shift light at 6600 and rev limit at 6800. I flycut my pistons. Make sure your valve train will hold up and consider stronger rod bolts.
Mar 21, 2007 | 01:38 AM
112 or 114 and did you flycutt i got the g5x3 on a 112 and goign to put it in april
Mar 22, 2007 | 01:50 PM
mdhmi
Fast 90/90, AFR 205 heads, LG long tubes, G5X3 114 cam, callaway honker.....
Mar 22, 2007 | 02:25 PM
I bought the G5X3 on a 112 and was told that flycutting was not required with the stock heads.
I plan on using COMP921 springs.
Mar 22, 2007 | 10:23 PM
St. Jude Donor '06-'07-'08-'09-'10,'13-'14,'19-'20-'21-'22
Max RWHP is at 6800.
Peak torque is about 5400 rpm.
Mar 22, 2007 | 10:30 PM
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Set rev limit at 7k
Shift at 6800 with a shift light, 66-6700 if you're watching the stock tach, which is known to lag a bit.
