Help with Tranny Cooler install.
Old Mar 20, 2007 | 07:27 PM
jgorss's Avatar
jgorss
Default Help with Tranny Cooler install.
I am installing a tranny cooler in my 04 coupe and I need to know what fitting to use to connect to the radiator and the return line. I am using -6 AN fittings on the cooler so I need a -6 to male (?) for the radiator and a -6 to female (?) for the return line.
Old Mar 20, 2007 | 10:38 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Hi--I installed a 6X10 cooler on mine and used -6 male X 3/8 flare male & 3/8 FIPT X 3/8 flare female-- Also a -6 male X 3/8 MIPT--No leaks they seal perfect--I got them at the local true value hardware store-brass fittings on some--Then I used female -6 swivels on the hose ends.
Oil never gets over about 190 and average about 160--used to get about 225 in town and 185 on freeway----I also installed a Deep sump trans pan adding 3 Qts.
Old Mar 21, 2007 | 05:44 AM
Blown 346's Avatar
Blown 346
I agree, If you do use brass fittings with AN fittings make sure you get use teflon paste. if you use a AN fitting to another AN fitting no paste or tape.
To Help with Tranny Cooler install.
