Will the stock exhaust manifold gaskets fit on Kooks headers? BTW it's a 01z. If not where can I get the gaskets?
Also, will get car pass emissions with a full exhaust?
Thanks...
I got the F-body gaskets, but Irish Whiskey is saying that there could be problems with it. Can anyone else confirm this, or can I just put them on like regular gaskets?
I used the OEM gaskets and have not had any problems. Dyno tested and hot ******* - so far all is well. The OEM gasket is an oval hole vs the Kooks round hole. The felt / metal gaskets from Kooks are crap so I tossed them.
OK, I'm getting mixed responses now- F-body with the round holes and the OEM with the oval holes . I'm guessing both gaskets line up with the bolt holes.
The holes we are referring to are the head exhaust ports and the header tubes at the header flange. The heads - even the ported ones - are oval whereas the Kooks headers are round. The mounting bolt hole pattern is identical. The OEM gasket will stick out into the round Kooks header tube about 1/16" or a little more at the "corners" of the oval. After driving for a while the metal gasket protusion will mostly burn off and no worries. I would mount the OEM metal gasket and not look back.
Good luck.
Not trying to disagree with you, but since the OEM would stick out, would the F-body one be a better fit?
Either will work. A lot of guys use the F-body gaskets and have no complaints. Personally I have no preference. I had alreadu purchased my OEM gaskets and when the Kooks came in I decided to use what I had since the Kooks header gaskets are crap.
