Code C1227 Excessive Wheel Speed Variation - ?
Old Mar 23, 2007 | 01:58 PM
d3m0's Avatar
d3m0
Default Code C1227 Excessive Wheel Speed Variation - ?
What in the world does that mean?
C1227 LR Excessive Wheel Speed Variation
What could cause this & how do I remedy this ?
Old Mar 23, 2007 | 02:29 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I don't have my service manuals to dig deep into this but is most likely one of your wheel speed sensors. The female connectors usually fail. The spring contact inside the female pin relaxes and cause a poor connection. What ever you do, don't fall into the trap of just ought right replacing the wheel speed sensor/hub! Troubleshoot it first!!
If you clear the DTC, does it come right back on or is it an intermittent issue?
If you clear the code does it come back as a H (history) or C (current)??
Bill C
Old Mar 23, 2007 | 02:31 PM
cliff_ford's Avatar
cliff_ford
Possibly the female connectors at each end of the wheel harness.
Old Mar 23, 2007 | 03:02 PM
d3m0's Avatar
d3m0
Hrm ... I haven't tried clearing it, I'll clear it and see what happens. I recently lowered the car on stock bolts, could any of that be the issue ?
What damage could be done if I don't do anything about this?
Old Mar 23, 2007 | 10:16 PM
Bill Dearborn's Avatar
Bill Dearborn
You could have accidentally moved or damaged the wheel speed sensor wiring/connector.
You can still drive the car but you will not have any ABS/TC/AH. If it is a 2001 or newer the Dynamic Rear Brake Propotioning may not work either.
Bill
Old Mar 23, 2007 | 10:33 PM
d3m0's Avatar
d3m0
Yea, My check engine light came on and then after that i am still cable to have TC and stuff. How can I check if i accidentally unplugged something ?
Old Mar 23, 2007 | 10:38 PM
berryj's Avatar
berryj
Do u have stainless steel brake lines? These codes can occur from aftermarket stainless lines.
Old Mar 23, 2007 | 10:44 PM
d3m0's Avatar
d3m0
I'm 110% Stock when it comes to suspension. I just lowered it on stock bolts, that's about it.
To Code C1227 Excessive Wheel Speed Variation - ?
