Light on DIC Control Panel
Old Mar 24, 2007 | 12:32 AM
blewbyuC5's Avatar
blewbyuC5
Default Light on DIC Control Panel
Anyone know why the lights on the E/M and Reset buttons on the DIC control panel are not on. The buttons function but the lights intermittently come on and off. If it was the fuse, i wouldnt think they would function. The light is lit for buttons 1-4.Thanks for any help.
Old Mar 24, 2007 | 01:03 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Your bottom bulb is loose or burned out, I'd imagine loose since you said it's intermittant? There are three bulbs in the DIC button pack. You'll have to remove the IPC to gain access to it... Do a search on IPC removal. many good instructions on here... You should be able to fix the loose connection. If it's a bad bulb here's the GM part;
GM Part # 16056613
Old Mar 24, 2007 | 01:14 AM
blewbyuC5's Avatar
blewbyuC5
Thanks!
To Light on DIC Control Panel
