iat sensor removal
Old Mar 24, 2007 | 11:20 PM
atomsmasher's Avatar
atomsmasher
5th Gear
Default iat sensor removal
does that grommet really poke out of the hole its in? seems awfully tight, anyone took the plunge and got that out?, thanks
Old Mar 25, 2007 | 12:39 AM
BaneZ06's Avatar
BaneZ06
Supremacy 1 car at a time
Just grab and pull it comes right out, on the reverse like work it back into the grommet
Old Mar 25, 2007 | 01:33 AM
Jim Taylor's Avatar
Jim Taylor
It'll wiggle out. If you're getting DTC P1111, several of us have had one of the wires break where it goes into the IAT connector. You might check it out with an ohm meter while you're there.
Old Mar 25, 2007 | 06:00 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Mar 25, 2007 | 09:25 AM
atomsmasher
5th Gear
Default iat
ok thanks i'll try again. yep i have the famous p1111 and th e p0113, i bet that wire is cracked somewhere, in fact i am in the middle of repairing a cracked wire in the lf wheel speed sensor pigtail, other than general cleanings i dont mess with the wires, its amzing to me how they just crack inside those harnesses, i'm getting better at finding them though , this forum saved me big time, many times, thanks again
To iat sensor removal
