change antifreeze
Old Mar 25, 2007 | 11:00 AM
corvettejaune's Avatar
corvettejaune
Default change antifreeze
where can 't find where to do a change ove antifreeze (how to do hit)on a 2000 vette and how much DEE-COOL i put after
thanks in advance and have a good day
Mick
Old Mar 25, 2007 | 11:23 AM
TEXHAWK0's Avatar
TEXHAWK0
There are lots of other posts on changing coolant.
If you do not want to flush the system, just open the drain **** on the lower right side of the radiator. You will get about 2 gallons out. Refill with a 50/50 mixture of dex-cool and distilled water.
The system holds about 12 quarts, so there is a gallon left in the block.
If you want to flush the system I would add distilled water, circulate, drain, and repeat until the water comes out clear. (meaning you have 4 quarts in the block of pure water)
To get the system back to a 50/50 mixture, add 6 quarts of pure dex-cool, then top off with water.
Old Mar 25, 2007 | 11:29 AM
TopFuelTim's Avatar
TopFuelTim
Thank you. I was preparing to search for this info, and found this.
Tim Glover
To change antifreeze
