I thought on the coupe and convertible you could see your transmission temperature(MN6). It was just the Z06 that had the Trans temp to high(MN12). Am I mistaken?
I think it's for the auto tranny that you can check temp not the manual trannys.
Yes the Auto trans you can check the temp. On the Z06 - MN12 there is also a high trans temp warning. the MN6 does not have this.
However, IIRC the temp sensor is in the drain plug of the MN12. I dont see why it could not be put in the drain plug of the MN6, unless one is using a trans cooler.
