C-5 Back Up Lights
Old Mar 25, 2007 | 08:29 PM
BELVIN20's Avatar
BELVIN20
Default C-5 Back Up Lights
I need someone to get me a copy of the wiring diagram of the back-up light circuit of the C-5, MN6. I need to see where the circuit is fused. I have not power at the plug on the trans. Any help will be appreciated.
Old Mar 25, 2007 | 09:21 PM
BaneZ06's Avatar
BaneZ06
Supremacy 1 car at a time
Old Mar 25, 2007 | 09:33 PM
BELVIN20's Avatar
BELVIN20
Diagram does not tell me what fuse runs the circuit. There is a Back-up light relay in the fuse block, but no fuse named for back-up lights. If I close the relay manually, the lights will light. The diagram does not show the power split to the trans switch. At the trans switch, I have not power.
Old Mar 25, 2007 | 10:01 PM
BaneZ06's Avatar
BaneZ06
Then what diagram do you want, you asked for the back up light wiring diagram and theres the back up light wiring diagram
Old Mar 26, 2007 | 02:02 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Under hood fuse box;
The Approach fuse feeds the Backup Lamp micro relay #38...
To C-5 Back Up Lights
