Problem with washer fluid sprayer
Old Mar 25, 2007 | 11:05 PM
DerekT's Avatar
DerekT
Default Problem with washer fluid sprayer
This has happened a few times, and it is beginning to annoy me.. some times, usually when I start the car, the washer fluid starts to spray onto the windshield without me touching the button. I let the reservoir run dry, but the motor will still try and spray. I figured out that if I touch the button half ways, or tap it, then it stops. Does anybody know what is causing this? It would be nice to be able to fill it back up with out having to worry about it randomly spraying everywhere... thanks in advance.
Old Mar 25, 2007 | 11:06 PM
VA CORVETTE 757's Avatar
VA CORVETTE 757
Well if you have a friend (with a C5), switch the washer fluid motor out of his car and into yours with his and see what happens. Easy to do!
Old Mar 25, 2007 | 11:29 PM
DerekT's Avatar
DerekT
I would, but have no friends with C5's.. do you think that is the problem though? I am thinking of pulling the motor all by its' self and being done with it.
Old Mar 26, 2007 | 12:04 AM
BanditDude's Avatar
BanditDude
It sounds like a short in the switch. It would do the same thing if you held the button down. Plus, you said that tapping it sometimes stops the motor...right?
Old Mar 26, 2007 | 10:39 AM
DerekT's Avatar
DerekT
Yes, If I tap it or press the button half way then it stops.
Old Mar 26, 2007 | 10:52 AM
FrogmanDave's Avatar
FrogmanDave
My button popped out the other day. When the button is out, there is no contact and the spray and wipers run. So it is a matter of the button making contact when not engaged and not making contact when you push it. The button pops out the end of the stalk with a small screwdriver. Pop it out and make sure the contacts are clean. Be careful...there are two small springs in there holding the button out and they can spring out and are hard to find.
Dave
Old Mar 28, 2007 | 10:54 PM
John Myrick's Avatar
John Myrick
I had the same problem with the washer pump. I changed the control stalk and the problem has not returned.
Old Jun 18, 2007 | 04:28 PM
OMG its Jason's Avatar
OMG its Jason
I know this post is old, but I just had this same problem last night, did a search and here it is...
Has this happened to anyone else?
To Problem with washer fluid sprayer
