I always use the Castrol 10W-30 or 10W40 on summer on my Ls1 Camaros SS..
I need to change oil for my Vette with uo to 55K miles and bought the Castrol Non Syntetic 10W40....
Im reading that almost everyboy uses Mobil 1, but I want to change oil now.... is any problem?, may I change it and in 3-4K miles change for Syntetic??
I recently noticed that Castrol Syntec 5W-50 meets GM4718M. (It never did before) I use it in my full-size Chevy truck and my 1974 Corvette. I have 250,000 miles on the 1974 Corvette using Syntec 5W-50. Blew three race prepped turbo400 transmissions in it but I am still running the same 350 cu-in engine without a rebuild.
First off, I would never use a non-synthetic oil in a C5. Secondly, there is really no reason to use a 10W oil during Summer months unless you are going to do some extensive track racing. 10W-30 is essentially, obsolete in this day and age. A synthetic 10W-30 doesn't pump up as quickly as a 5W-30 or 0W-30 oil during startup, but will certainly not wear out your engine significantly faster.
I dont understand why, some of people still think that 10W would never work and 5W is the hole world difference!!
Fisrt of all, in the city I live, the lowest temp is about 25Celsius, like 80°F, so 0 or 5W will never really be neded is my tought.
On the other side, the 40 are better than the 30 beacause my Vette still dont tune for early turn on fans y dont have 160° thermostat and always works between 200 and 250° so, I think woild be better 50m but I think 40 is good.
The first number is the oils ability to flow at 40* C. Why not have the best flow possible? The higher the first number...the longer your motor is starved of oil each time it is started when cold.
