Oil pressure sensor
Old Mar 26, 2007 | 05:13 PM
harleyvette's Avatar
harleyvette
Default Oil pressure sensor
I know this has been talked about for some time but! can you remove and replace the oil sensor without removing the intake? and how?
Old Mar 26, 2007 | 05:29 PM
toxdoc's Avatar
toxdoc
It's on page 4 of the "relocate" sticky at the top of this forum.
Old Mar 26, 2007 | 06:38 PM
Oldvetter's Avatar
Oldvetter
Yes, you can take off the window wiper panel and then cut a hole in the body panel. Some people said this lets in more noise.
Another way to prevent taking off the manifold IN THE FUTURE, is to do a remote location for the sensor. But this won't help you the initial time, as you still hve to take manifold off to do this.
BUT, I guess you could cut a hole AND remotely locate your sensor !
Look at stickys for procedures.
Old Mar 26, 2007 | 06:57 PM
sigma6's Avatar
sigma6
It really doesn't take very long to replace this sensor. You should be able to do it in 1.5 hours the first time and a lot quicker than 1 hour thereafter.
Old Mar 27, 2007 | 12:17 AM
rws.1's Avatar
rws.1
Read the sticky...
Taking my time it took me about 2 hours to do the R&R
Not hard, anyone can do it following the instrucions in Vectorz post.
Old Mar 28, 2007 | 10:13 PM
harleyvette
Where can I get the info to do the remote?
Old Apr 28, 2007 | 04:59 PM
kayakmc's Avatar
kayakmc
If you do the "cut the hole in the panel under the wiper blades" be sure to stuff a rag back between the engine and the firewall. I almost lost the new switch back there, took 20 min to fisk it out.
Old Apr 28, 2007 | 06:47 PM
rws.1's Avatar
rws.1
here's the link for you
http://forums.corvetteforum.com/show....php?t=1588172
Old Apr 28, 2007 | 07:54 PM
JPCCDD's Avatar
JPCCDD
i just cut the hole. took 20 mins. except now i gotta open it all back up cause i forgot to put some tape over the hole i cut. now the smell of the engine compartment makes its way into the channel and into the a/c vents.
To Oil pressure sensor
