water pump help!!!
Old Mar 28, 2007 | 12:34 AM
cracker Bear's Avatar
cracker Bear
Default water pump help!!!
ok so i put on some mods today started my car to go get a can of snuff,, and this awful squeeling noise came from my hood ... so i opened it and determined that it was the tensioner pully.. so i got a new one and a new belt and put it on..... didnt help.. now i think that its my water pump,,, do i have to buy a new pump or is there a bearing that i could put in there,,, hmm now that i think about it i will most likely have to get a new pump... sooo what i want to know is if any of you guys have run into this problem and what yall did to solve it,, and does any one have a water pump that dont cost 160???? im gona tear the top and front down tommorrow,,, i just need some help here
Old Mar 28, 2007 | 03:47 AM
Blown 346's Avatar
Blown 346
If your getting a squeel, the belt might need to be repleced if it hasnt been already. Look at the belt to see if it has a glazed look about it( on the smooth side). Also check to make sure it isnr dry rotted or splitting. If thats the case its the belt.
Otherwise the water pump pulley bearing might need to be replaced. If the water pump was bad you would see fluid coming out of the weep hole.
To check bearings, place you finger where the bearing sits and rotate it. It should be smooth, if it isnt time to replace it. You can do that yourself with a hammer and a piece of wood. I would check other pullies as well to make sure you have the culprit.
Old Mar 28, 2007 | 05:38 PM
Jim Taylor's Avatar
Jim Taylor
It's been a while and I don't remember the exact location, but there's an idler pulley under the water pump or power steering pump. That was where my squeak was coming from. You might try the old "piece of heater hose used like a stethoscope" trick to see if the sound is coming below the water pump.
Old Mar 28, 2007 | 05:41 PM
cracker Bear
yup you are right,,, i took it all of and the idler pully as well as the second blet tensioner pully were bad,,, Thanx a million
To water pump help!!!
