Rear Sway Bar Removal ?
Old Mar 28, 2007 | 06:09 PM
Oldvetter's Avatar
Oldvetter
Default Rear Sway Bar Removal ?
Can rear sway bar be removed while tires are on the ground?
Are torque values 49 ft-lbs for bolts and 70 ft-lbs for nuts on the sway bar bracket?
I just want to grease the sway bar bushings.
Thanks.
Old Mar 28, 2007 | 06:46 PM
GreyGT-C's Avatar
GreyGT-C
yes.... can be reached on the ground....
not sure about the torques
Old Mar 29, 2007 | 11:38 AM
Last C5's Avatar
Last C5
Your torque values are correct 49 ft lbs for the upper bolt and 70 ft lbs for the lower nut. The end link nuts are torgued to 53 ft lbs.
Old Mar 29, 2007 | 11:52 AM
DefenderC5's Avatar
DefenderC5
Good luck torquing the end links, I could never fit a torque wrench in there... just get them really tight.
On a positive note, you don't need to take off the end links to grease the bushings. Just undo the bolts/nuts on the brackets, the sway bar will swing down and you can access the bushings.
Grease here:
1) Inside where the bushing contacts the bar
2) Outside the bushing where the bracket contacts to bushing
3) The flat side where the bushing touches the crossmember
You don't need gobs of grease, just a good coat on all the contact areas. My bars are dead silent.
Old Mar 29, 2007 | 04:55 PM
Oldvetter's Avatar
Oldvetter
Thanks everyone, that's just what I needed.
DefenderC5, good call on lubing all those surfaces, I would not have done that !
Old Mar 29, 2007 | 05:04 PM
LoneStarFRC's Avatar
LoneStarFRC
I have found that synthetic brake caliper grease works well for me. Cheap and available most everywhere.
Old Mar 29, 2007 | 06:51 PM
Oldvetter's Avatar
Oldvetter
I'm sure it does and it is probably close to what I use, diaeletric grease, it's recommended by GM for gaskets and rubber parts. It is basically silicone grease.
Old Mar 29, 2007 | 10:06 PM
davidfarmer's Avatar
davidfarmer
the high torque is for the bolt with the nut on the end (lower control arm), and the lower torque is for the one that threads into the subframe. DON'T strip that one, or your screwed!
Old Apr 23, 2007 | 12:50 PM
98blackonblack's Avatar
98blackonblack
CAn I jack the rear of the car up and take the sway bar off no prob..?
Also I need to replace the end links on the sway bar the rubber seals are all messed up...suggestions on replacements?
Old Apr 23, 2007 | 04:12 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
There are no rubber seals on the sway bar end links unless you have some type of aftermarket links.
Old Apr 24, 2007 | 11:19 AM
98blackonblack
Its like the seal on a ball joint.
Old Apr 24, 2007 | 11:27 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
It sounds like you need some new end links. Buy some metal one's from GM or from VBP.
The stock one's are plastic and the newer metal one's will improve your handling.
Old Apr 24, 2007 | 03:25 PM
Uncle John's Avatar
Uncle John
The stock plastic ones do have a rubber seal on them. Junk though.
Hey Tony!
To Rear Sway Bar Removal ?
