Need help with DIC trouble code
Old Oct 13, 2001 | 10:01 PM
jcarlson's Avatar
jcarlson
Default Need help with DIC trouble code
I've been getting the check engine light lately. I've taken it to the dealer THREE times and they haven't fixed it yet. The code is: PCM P0410 AIR System-B
They said they replaced a valve in the emissions system, and an oxygen sensor. Taking it back a fourth time is rediculous. Does anyone have an idea of what this may be? Maybe I can help to stear them in the right direction.
Thanks for any suggestions,
Jason
Old Oct 13, 2001 | 10:52 PM
blkvet's Avatar
blkvet
Default Re: Need help with DIC trouble code (jcarlson)
i just posted this in another topic.. I am having the same problem as you.
here is what i wrote:
id REALLY appreciate a translation on these codes i have..
10-PCM - P0410 HC <- this one i believe is the reason my check engine light is on.
and these are past codes i had.. im wondering if when i reset these if the 'H' goes away.. i would prefer not to keep a record of prior fixes in the computer..
here is what it sez:
A0-LDCM - B2282H, B2284H, V1064H
A1-RDCM - B2283H, B2285H, V1064H
B0-RFA - V1255H, V1096H, V1064H, V1016H
i had got my vet back from the shop not 1½hr when the check engine light came back on..
Old Oct 14, 2001 | 11:14 AM
c5wrench_2001's Avatar
c5wrench_2001
Well, first off, your sensors or your check valves would affect a different code, either a p1415 or a 1416.
I am suspecting either a pump, or the ground side of the pump.
If it was a relay, you would see s p412, and if it was a solenoid, or control circuit, a 418.
I would say your being shotguned at your dealer, c5wrench
To Need help with DIC trouble code
