batteries for TPS ?
Old Mar 28, 2007 | 07:49 PM
telegraph's Avatar
telegraph
Default batteries for TPS ?
What kind of battery is used in the Tire Pressure Sencors? Where can they be bought? And can they be easily installed when I get my new tires mounted? I have one sencor that is not working. Thanks for any help or advise!
Old Mar 28, 2007 | 07:51 PM
B-rent's Avatar
B-rent
have you tried getting the car to re-recognize them again? id try that first
Old Mar 28, 2007 | 07:54 PM
corvettedoug's Avatar
corvettedoug
There are two version of the TPS monitors. One covers years 1997-2000 and the newer version is from 2001-2004. The older ones are more expensive(New ones are about 40 bucks a piece I think). I have not changed the batteries myself, but I believe you have to cut open the sensor to replace the battery and put a new one back in.
By the way, if you are receiving an XX error for a monitor you can go through the reprogram process yourself and reset each sensor with a large magnet (such as an old speaker). This might fix the problem without putting in new batteries. Just do a search on the forum for the directions.
Old Mar 29, 2007 | 01:12 AM
my6thvette's Avatar
my6thvette
The original battery in the 1997-2000 sensor is a 3V Renata CR2477N lithium battery. It has leads welded to it to connect to the circuit board. You can also use a Panasonic BR2477A/VA, which comes with the leads already attached. Available from Digi-Key. For installation directions see:
http://forums.corvetteforum.com/show...1030589&highli...
Old Mar 29, 2007 | 06:04 AM
Greg_E's Avatar
Greg_E
If your sensor is out of a 97-2000 and you decide not to rebuild it, I'd be interested in buying it. I need one more to complete a set of four that I'm rebuilding. Let me know.
Old Mar 29, 2007 | 06:23 PM
telegraph's Avatar
telegraph
I am going to try to get the car to reconize the sencor. If this doesn't work I'll get back with you.
To batteries for TPS ?
