Top Speed w/ A4?
Old Mar 29, 2007 | 06:29 PM
DBLX's Avatar
DBLX
Default Top Speed w/ A4?
Hello all,
What top speed will I get with 3;15 gear and same for a 3:42 gear? Can you run wide open on the top end in 4th(OD)? I guess the real question is the OD band strong enough to do this?
TIA,
Malcolm
Old Mar 29, 2007 | 07:18 PM
Oldvetter's Avatar
Oldvetter
Top speed is governed by Horsepower and aerodynamics. That's why Coupe has faster top speed than Z06.
Old Mar 29, 2007 | 10:12 PM
tiojames's Avatar
tiojames
Don't know for sure about our cars, but I had a Trans-Am with an auto- basically the same tranny we run, and the guy who built it for me told that long hi speed runs on a stocker would eventually do in the OD unless it had a cooler and some interior work.
Old Mar 29, 2007 | 10:34 PM
fastfb350's Avatar
fastfb350
don't forget gearing... That has to do with it to. If I'm not mistaken a c5 coupe tops out at 183 mph.
Old Mar 29, 2007 | 10:55 PM
rkerr1234's Avatar
rkerr1234
I have a sales training manual from Chevy, it says 175+
Old Mar 29, 2007 | 11:02 PM
zo6chik's Avatar
zo6chik
the z has a lower top speed than the coupes, due to the lower gearing. it will get to its top speed faster than the coupe because of the same reason (it has nothing to do with aerodynamics, theyre very similar). as to top speed on an a4??? prob too fast for you to worry about.
Old Mar 29, 2007 | 11:52 PM
SpeedyD's Avatar
SpeedyD
Never had to do this before, but I'm gonna do it now That's on the aerodynamics part of your statement. The aerodynamics are much better at top speeds and this is why with the new Z06 they used the coupe shape, but it's a fixed top for rigidity!! Even a little difference makes a huge improvement at those kinds of speeds.
Old Mar 29, 2007 | 11:54 PM
CKMark's Avatar
CKMark
I've hit 155 in a 2002 Red C5.
Old Mar 29, 2007 | 11:55 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
I hit 80 one time, I think it was about maxed out
Old Mar 30, 2007 | 12:14 AM
geterdone's Avatar
geterdone
Its gearing on a Z06, I can pull mine to 175 and it is still pulling strong until I hit rev limiter. Sure there is some aerodynamics but that is not the reason.
Old Mar 30, 2007 | 12:17 AM
zo6chik's Avatar
zo6chik
im with geturdone....sure the z has more drag than the coupe but the point i was making was as geturdone stated, "its the gearing"
Old Mar 30, 2007 | 02:22 AM
John Micheal Henry's Avatar
John Micheal Henry
in 2nd gear
Old Mar 30, 2007 | 03:54 AM
Jeffyvette's Avatar
Jeffyvette
Default For a Vert
I got 168 with the top down. It was a loud with the wind noise. It is an A4.
Jeffy'
Old Mar 30, 2007 | 08:33 AM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
WOW ... Wonder what a Pewter one would do?
Old Mar 30, 2007 | 09:49 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
1st Gear?
Old Mar 30, 2007 | 09:53 AM
RedY2K's Avatar
RedY2K
Old Mar 30, 2007 | 10:39 AM
robvuk's Avatar
robvuk
It has been WIDELY publicized since the very beginning of existence for the FRC that the aerodynamics hold it back on the top end.
Either car is GEARED for over 250mph but they are both drag limited to their top speeds and the coupe is about 8mph faster in spite of 55 less hp.
To Top Speed w/ A4?
Old Mar 30, 2007 | 10:51 AM
MTurnbo's Avatar
MTurnbo
I can tell you that my vert can handle a LOT higher top speed than the driver can!
Old Mar 30, 2007 | 11:37 AM
blown in n.c.'s Avatar
blown in n.c.
163 with 3.73s and a built A4, but it comes sooooooo fast
By the time a stocker/other sports car gets to 163 they'll be out of road
Old Mar 30, 2007 | 11:51 AM
chaase's Avatar
chaase
St. Jude Donor '12
What gear where you in that you were hiting the rev limiter. I believe that top speed is in 5th, because you need the extra gear in 5th to overcome drag.
