Injector size in stock 2000
Old Mar 29, 2007 | 09:55 PM
patrickC5's Avatar
patrickC5
Default Injector size in stock 2000
I have the stock injectors in my 2000 are they the 26.2lb ones? The reason I ask is I was getting a touch up tune and the tuner said they maxed out at 109% at 6300rpm. All I have is bolt ons and a MS3 cam and I am done with power adders. Also are the stock ZO6 injectors 28.8or 30lb? My tuner says he has some 30lbers from his ZO6 that he will sell me but I didnt ask him if they were stock. If they were stock they should be 28.8 correct? I know injectors have been covered to death I spent the past 2 hours reading and I think my eyes are bleeding. I just want to make sure I have things straight.
Old Mar 29, 2007 | 10:27 PM
IFLUBYU's Avatar
IFLUBYU
stock for 2000 are 26.4# I thought, stock for c5 z06 are 28.8 correct. You would be fine with either the 28.8 or 30#ers.
Good luck!
Old Mar 29, 2007 | 10:30 PM
SLPRC5's Avatar
SLPRC5
30 # are better with mods..
Old Mar 29, 2007 | 10:37 PM
patrickC5's Avatar
patrickC5
Thanks guys I thought the ZO6 was 28.8. I didnt realize till tonight that the 99-00 had smaller injectors. I know the 30lbers are better cause they really flow about 36 with our fuel pressure. I hope he put in some aftermarket SVOs or something and he isnt trying to sell me the stock ones thinking they are 30lb. I agree IFLUBYU I think I should be all set even with the 28.8's but I would rather use the 30lbers to be safe. I am almost tempted to keep the stock ones if the AFR is still stable. I have not seen the log from the run yet so I dont know.
To Injector size in stock 2000
