signal lights problem...
Old Mar 30, 2007 | 04:48 PM
ganna001's Avatar
ganna001
Default signal lights problem...
occasionally, when i signal right or left, the signal lights willl stop working alltogether... but if i press the emergency light button, they start working again.
anybody have an idea whats goin on?
this is a 2000 vette.
Old Mar 30, 2007 | 06:56 PM
Z06 R.Ph.'s Avatar
Z06 R.Ph.
I hope someone has an answer to this concern. I have just experience the same thing with my car. It is a 2002 Z06. I am not certain what caused my signal lights to stop working, then begin working again. Thanks in advance.
Old Mar 30, 2007 | 07:10 PM
Last C5's Avatar
Last C5
Congratulations! You both own C5 Corvettes. Your flasher is going out. You've already found that by punching the hazard switch a couple of time the signals start working properly again, but this fix only lasts so long. The signal flasher in an integral part of the hazard switch. You need to pull the console, radio bezel, and radio. This will allow you to get to the flasher and pull it/fish it down and put a new one in. Buy the new one first so you can see how it clips in. You can only reach one side of clips, but after thats loose you can push, with some effort, the unit out the back side. Do a search and you find a do it yourself write up with pictures.
Old Mar 30, 2007 | 08:04 PM
B's00Vette's Avatar
B's00Vette
I forgot who I got this from, but this is exactly how to do it ->
http://myweb.cableone.net/kd5fx/HSwitch/HSwitch.htm
B
Old Mar 30, 2007 | 09:55 PM
jdmvette's Avatar
jdmvette
Night Owl for life
what's the part number for the replacement part?
Old Mar 30, 2007 | 10:40 PM
B's00Vette's Avatar
B's00Vette
I don't have the part number, but I got mine from ecklers.com
Old Mar 31, 2007 | 11:41 PM
docohm's Avatar
docohm
The Part number is shown in the instructions I posted, see the link above.
You're welcome...
Docohm
(also kd5fx)
To signal lights problem...
