Rear going south possibly
Old Mar 31, 2007 | 06:27 PM
YO-EL's Avatar
YO-EL
Default Rear going south possibly
Today while my car was jacked up to change drag radials (EM brake was off), when I went to the first torque setting of 60lbs with my torque wrench, the wheel spun & couldn't hold unless I held a spoke..
The other side did the same, spun freely..
Is this a bad rear or sign its going.. Before it always held torque to 60 lbs no problem at all, and then I would lower the car & torque to 80lbs, then 100..
Ellis
Old Mar 31, 2007 | 06:39 PM
2000BSME's Avatar
2000BSME
Ellis
I'm thinking yes, but I don't know for sure. Why are you torqing to 100? I thought 80 was the 'number'.
-nevermind, 80 is the 'lubed' torque, and 100 is the dry torque.
Old Mar 31, 2007 | 08:13 PM
schpodie's Avatar
schpodie
I am curious about this, I would have thought they should spin? If not then mine probably has an issue. Should one spin and the other not (if you have the car up and are only turning one)? I'd love to know too!
Old Mar 31, 2007 | 08:39 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Mar 31, 2007 | 08:43 PM
Mike Mercury's Avatar
Mike Mercury
I've always ended at 100
Old Mar 31, 2007 | 08:48 PM
2000BSME's Avatar
2000BSME
It depends on what type of rear end (traction) your car has. Most vettes, and I think all c5's should have both rear wheels held together when spinning by the rear clutch pack. Lots of cars have 'peg leg' rears, where when up in the air, and one wheel spins, the other goes in the opposite direction. My 1500 truck has a different type of positive traction in the rear, which I think is a more positive engagement, that won't allow any slippage between the two rear wheels once engaged, but it doesn't stay engaged during normal driving, only when wheel slippage is detected, does it 'lock up'.
There are many different types though, among the different manufacturers.
One thing that I always thought was funny is the 4 wheel drive vehicles that have 'open' differentials in the front and the rear. They aren't really 4 wheel drive, you could actually get one stuck on 2 wheels if they were diagonal to each other. My friend had a jeep that was a good example of this, we even got it 'stuck' to test the theory.
To Rear going south possibly
