how to depressurize fuel system.
Old Apr 1, 2007 | 10:40 AM
tommybilt's Avatar
tommybilt
Default how to depressurize fuel system.
About to change the fuel filter. How do I depressurize this thing so I dont wear some high octane?
Old Apr 1, 2007 | 11:15 AM
kromberg's Avatar
kromberg
Let it sit over night. It will naturally depressurize overnight.
Keith
Old Apr 1, 2007 | 11:19 AM
Oldvetter's Avatar
Oldvetter
Take off your driver side engine cover. At the front end of the fuel rail there is a shrater (sp) valve, like on your tires. Remove cap, set a large rag there (to catch gas), depress valve. Gas will squirt out.
Still watch your eyes, as some gas will drain when replacing filter. Also push fuel filter together, use tool, and then pull apart. You can release using fingers also.
Old Apr 1, 2007 | 11:26 AM
GreyGT-C's Avatar
GreyGT-C
i pulled the fuel pump fuse while the car is running..... system will be depressurized in about 2 seconds.
Old Apr 1, 2007 | 11:43 AM
Oldvetter's Avatar
Oldvetter
Very creative !
Old Apr 1, 2007 | 11:46 AM
Mike04's Avatar
Mike04
That is what I'd do.
To how to depressurize fuel system.
