Lifter question
Old Apr 1, 2007 | 01:41 PM
Corvette Don's Avatar
Corvette Don
Default Lifter question
I am doing tsp stage 2.5 heads and a 233/239 cam, what set of lifters should I go with? Are the factory lifters going to be able to withstand the abuse???
Old Apr 1, 2007 | 02:03 PM
htvette's Avatar
htvette
I went with LS7 lifters (TSP 2.5 stg 232/234 cam). It's only a little over 100 bucks.
Old Apr 1, 2007 | 02:22 PM
tjwong's Avatar
tjwong
You can use the factory lifters if they are in good shape. But if you are doing a complete head and cam swap, you are right there so getting a new set of lifters would be very wise. As the previous member list mentioned, the best bang for the money are the GM LS7 lifters. I use these in all my head and cam jobs and also in many small block applications as well. These semm to be much more reliable and easier to use than the Comp Cams Comp-R lifters.
Old Apr 1, 2007 | 04:58 PM
94legaleagle's Avatar
94legaleagle
And the LS7 lifters are said to limit, if not remove, the sewing machine noise
Old Apr 1, 2007 | 05:01 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Alot of people are also going with the Caddy racing lifters. These are what I will probably put in this summer....
Chris
Old Apr 1, 2007 | 05:32 PM
Corvette Don
Looks like ill be getting the LS7 lifters from tsp for $135, thanks guys
Old Apr 1, 2007 | 05:34 PM
chriswtx's Avatar
chriswtx
LS7 lifters are $100 from SDPC part#12499225
Old Apr 1, 2007 | 08:05 PM
Corvette Don
Ok cool thanks a lot man
Old Apr 1, 2007 | 08:19 PM
WKMCD's Avatar
WKMCD
Spend the noney for the Cadillac Racing Lifters.
Here's a comment from someone I gave a ride to after the 403/L92 build:
I just road in this car...
Of all the rides I have been in this is absolutely the most mechanically quiet. I simply don't understand it, 13 degrees overlap and the steering wheel was not shaking at all at idle. You hear the car from the exhaust, not from under the hood...
Throttle response was brutal and rolling through 3rd gear flat puts your *** in the seat.
I was one of the original skeptics from earlier posts and I am not afraid to admit I am now eating crow about this.
Absolutely the most civilized 500rwhp I have ever experienced... Props to all those involved
Old Apr 1, 2007 | 09:24 PM
SLPRC5's Avatar
SLPRC5
This testimony is GREAT encouragement!!! I have been waiting 2.5 months for my Caddy Race Lifters to be shipped to me. Holding up installing my new Patriot heads. There s a back order because GM is behind in producing more of them. So SDPC assures me that they should receive a new batch on April 7.
All I can do is WAIT.
As recommended by WKMCD..these are the ones to get.
Old Apr 2, 2007 | 12:17 AM
94legaleagle
I got lucky and got a set after a couple weeks this past January - I love them, and very little, if any lifter noise - WELL worth the wait, so hang in there!
Old Apr 2, 2007 | 12:32 AM
tjwong's Avatar
tjwong
They will eliminate the noise if and only if the proper preload is applied to the lifters. So in saying that it is very important that your installer checks for proper push rod length and preload on the lifter. Most of the time a 7.400" push rod can be used without any issues. Then with some cam profiles and head combinations a longer or a shorter length is required depending on how much the heads were milled, head gasket thickness and cam profile. For instance I just installed a sleeper cam into a new C6 LS2 using the stock heads and stock head gaskets, in this instance I actually had to use a 7.450" length to acheive the proper preload on the lifter. After the installation and engine start up, the car ran as quiet as if it was built in Bowling Green. This cam is a .631/.644 lift so the base circle is considerably smaller than a stock cam so a longer push rod was needed in this case.
Old Apr 2, 2007 | 01:03 AM
geterdone's Avatar
geterdone
How much do the Cadillac lifters cost?
Old Apr 2, 2007 | 08:44 AM
billiardcue's Avatar
billiardcue
What is the correct preload for the Caddy lifters?
Old Apr 2, 2007 | 09:46 AM
WKMCD's Avatar
WKMCD
I think they were about $200 from SDPC.
Old Apr 2, 2007 | 10:38 AM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Caddy Lifters =$217.00
The current price from SDPC is $217.00 per set.
Bob K.
Old Apr 2, 2007 | 03:30 PM
Corvette Don
So will I be ok with stock pushrod length on TSP stg 2.5 5.3L heads and a 233/239 cam with LS7 lifters or will I need longer or shorter?? Please someone chime in before I order
To Lifter question
Old Apr 2, 2007 | 03:40 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
^ Only way to truly tell is to get a pushrod length checker and measure, then order your pushrods.
FYI stock is actually 7.38X vs. the 7.4s... I compared my oem to new ones when putting my cam in.
Many guys put 7.425s in for a little more pre-load... I went ahead an went w/ the 7.4s b/c that's what came w/ my LGM kit... also, I'll probably install milled heads down the road.
My car is only marginally lounder than stock, but I have yella terra full roller rockers.
Old Apr 2, 2007 | 04:11 PM
SLPRC5's Avatar
SLPRC5
That's the plan..hopefully a couple of weeks out.
Old Apr 2, 2007 | 06:03 PM
chriswtx's Avatar
chriswtx
Just call Texas speed since your using there heads. 7.4" rods should work fine if the heads were not milled...
