Doing some routine maintenance on the 00 Vert with 95K. One of the things I thought I should do is to have the clutch fluid replaced and clutch adjusted. No issues with the clutch but with the amount of miles, I thought it was a good idea to do.
My local dealership said, absolutely no way should I do that. The fluid does not break down similarly to that of brake fluid and if the clutch is not giving me a problem, don't worry about it.
Your thoughts?
VETSTYL
Search "Ranger" threads on clutch maintenance....even if you disagree with the threads the fluid is the same fluid for brakes and clutch, if it's not a nice golden colour and shows up black, positive advice is to change it.
Ian
With that year and miles it breaks down, just look at it. I would at least suck it out of the reservoir and add new. On my 01' with 44k I even saw a little mud on the bottom,cleaned it out too. Sneak in the kitchen and borrow the turkey baster, works good. Use the same fluid as for brakes. I would even do it once a month for few months till it looks good. Your brake reservoir would like it also, or bleed it all out after you suck it out.
