Pressure switch a/c
Old Apr 2, 2007 | 11:48 AM
ettev99's Avatar
ettev99
Default Pressure switch a/c
How can i bypass the switch to see if the clutch will engage on the compressor. If it does that tells me the switch is bad...right? I jump 12 v to the compressor and the clutch engage,i'm suspecting the pressure switch.
Old Apr 2, 2007 | 01:33 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I dont think you can safely jump the switch. It isnt just a two wire pressure switch. It contains some sort of three wire electronic componet. You can replace the switch without depressurizing the system. It unscrews from a schreded valve. That prevents loss of any freon.
BC
Old Apr 2, 2007 | 01:52 PM
ettev99's Avatar
ettev99
Thanks Bill maybe i should get the pressure check first if there's a leak i understand the clutch wont engage
To Pressure switch a/c
