G5X3 owners
Old Apr 3, 2007 | 08:21 PM
Indiana Z06's Avatar
Indiana Z06
Default G5X3 owners
I am seriously thinking about getting the G5X3 cam and was wondering for the owners of this cam--if you had the heads milled and used the stock short block, did you feel like you lost low end torque or did it feel somewhat stock on the lower end? Thanks.
Mark
Old Apr 3, 2007 | 09:14 PM
Vette-Red's Avatar
Vette-Red
I don't have the g5x3, but I do have a 238/242 .609/.615 on a 111lsa and it is a lot harder to start in first, now. I think I need to go with 3.90's or 4.10's to make up for the bigger cam. It does feel like I lost some low end grunt, but I think a new gear will make up for that. To me it feels like there is no middle ground when taking off, either you have to really feather out the clutch or bog down on the takeoff; doesn't seem like there is anything in between. I am also on the stock heads, one shop said that a p&p on the heads might solve some of those problems.
Old Apr 4, 2007 | 12:20 AM
Phat Ride's Avatar
Phat Ride
I have the G5X3 cam @114 lsa, stock heads, LT headers, Borla Stingers, Manual trans., 3.42 gears. I agree that the car lost some low end grunt, when taking off you have to feather the clutch quite a bit to get a smooth launch. I am going to switch to 4.10 gears to try and balance out the lack of low end torque. I would like to do the heads for overall HP increase, but not sure if it would help with lower rpm performance.
Old Apr 4, 2007 | 06:37 AM
EdsC6Z06's Avatar
EdsC6Z06
St. Jude Donor '05-'06-'08-'10
I have the G5X3 with no headwork. Car does lose some low end grunt, and smooth stoplight launches require practice with the clutch. However, from about 3000 rpm's and up the car rips.
Old Apr 4, 2007 | 08:45 PM
Vettedreamer2's Avatar
Vettedreamer2
I have the X3 on 114. With a good tune I have no problem with first gear. Run rpms to 1500 and feather out. I agree the car is super power full from 3000 up. I am making 402RWHP with header, cam and under drive. Heads and intake stock.
You will need to get 921 springs to go with the large lift. I would check with LG on how much you can shave off because of PTV clearance. The extra compression should make up the low end power.
Old Apr 5, 2007 | 10:41 PM
Skinny Kid's Avatar
Skinny Kid
I have the G5X3 on a 112 and it has tons of grunt. Compared to my friend's stock 04Z it feels stronger all throught the powerband. Sometimes it just feels like it lost torque because of the massive power gain up top when in reality it actually gained a few lbs./ft.
Justin
Old Apr 5, 2007 | 10:52 PM
Tuner@Straightline's Avatar
Tuner@Straightline
Last G5X3 (or very similar custom grind) C5 we did, also had a set of Patriot LS6 heads on it. Car was a M6 with stock gearing. Under 3800rpm, the HP curve was almost identical, picking up only 5rwhp, but then at 3900rpm it looks starts making a huge difference in HP. If I can get the dyno graph scanned, I can try to post it. Under 3800rpm that cam makes about the same as a stock cam, but by 4000rpm it's a rocket.
Old Apr 17, 2007 | 10:40 PM
Indiana Z06
Thanks guys. I know this is an old thread, but I was just seeing if anyone else had any details.
To G5X3 owners
