Has anyone put LS6 Heads on an LS1 Engine? How much of a gain in BHP would be expected on an N/A LS1 if any?
Is that really a question? Honestly try "Searching" I'm sure you could find a gazillion threads on LS6 head installs. Hence the lack of responses your getting.
I was told that up gradeing to LS6 heads on a LS1 would yeild about 15hp, if you do the LS6 cam too you would see about 30-35hp as I was told. Not worth it imo unless you can get them dirt cheap
A Flash, must be that time of the month again huh?
you can get some CNC upgraded LS2/6 heads with upgraded springs and port and polish for under 1K
I would check out Ls1tech.com and ask around there for some Known workable power combos, if you going to do a heads and cam swap then you want to make more that stock z06 power for the money its going to cost you
You would need to upgrade the cam also to see any power gains.
false....its 15 for just the heads at peak. You can get 14 for just the compression bump from 10.1:1 to 11.1:1 which works even with the stock cam.....and thats 20 rwtq for the compression alone.
PP LS6 heads, and great cam will get you much more then that.
