brake fluid inquiry
Old Apr 4, 2007 | 10:27 AM
projectnightmare's Avatar
projectnightmare
Default brake fluid inquiry
Guys
I am swaping out my entire brake system and suspension this weekend on my 99 coupe. I am going to drain all existing brake fluid and then replace it with new fluid, how much volume of break fluid do I need to purchase to refill the brake lines, resevoir, calipers, etc...
What's your opinions on which fluid I should go with? The car will be driven around aggresive street drive/road course but also a daily driver... I will have bigger calipers, Rotors and stainless steel lines... I've been looking at Redline's product, but what's been your experiences?
Old Apr 4, 2007 | 11:32 AM
nmbis2k's Avatar
nmbis2k
just make certain that you do not drain the ABS dry. I just keep topping the resevour up with new fluid.
I like the full synthetic DOT 4 from Valvoline.
I recalled needing two bottles....since it took something over one.
Old Apr 4, 2007 | 11:35 AM
FASST LN's Avatar
FASST LN
Yes, two large bottles. (Maybe each bottle was 16 ounces?)
Old Apr 4, 2007 | 12:22 PM
AU N EGL's Avatar
AU N EGL
Brake fluid thread
http://forums.corvetteforum.com/show....php?t=1660115
Old Apr 5, 2007 | 12:28 PM
thetorch's Avatar
thetorch
Motul RBF600
To brake fluid inquiry
