Need Some Power For An A4
Old Apr 4, 2007 | 10:50 AM
NTRBL33's Avatar
NTRBL33
From: The United States of TEXAS www.corvettemotorsportsinc.com
St. Jude Donor '07-'08-'09-'10-'11
Default Need Some Power For An A4
My bud as an 02 A4 273 rear and wants some SOTP power, he as already installed a vararam. He wants a little lope and some decent power, nothing over the top. I was thinking cam,tune and headers.
What have yall done or recomend? Thanx in advance
dlj
Old Apr 4, 2007 | 11:02 AM
_Will_'s Avatar
_Will_
From: Somewhere between mild insanity and complete psychosis
Cam, TORQUE CONVERTER, tune, headers.
Not over the top:
American Racing Headers
Vigilante 2600-2800rpm converter
Thunder Racing 224/224 cam
Springs, retainers, valve locks, etc.
That cam is a long time proven performer, easy to tune, and very middle of the road. Not too big, not too small.
A 2600 or 2800 converter should be good w/ 2.73 gears. Bigger stalls will be very loose without a gear change.
What is the budget limit for parts?
Old Apr 4, 2007 | 01:02 PM
NTRBL33's Avatar
NTRBL33
Not over the top:
thats the line of was thinking. I had that cam in my c5 and lg if running a special on street headers. Probably not a stall though.
thanx for the input.
dlj
Old Apr 4, 2007 | 01:05 PM
_Will_'s Avatar
_Will_
dlj
that cam may be pushing it for a stock stall. If no stall swap, I'd play it safe and go a little smaller. TSP 220/220 on 116LSA or Comp 212/218 on 114 LSA for example.
Old Apr 4, 2007 | 01:09 PM
NTRBL33's Avatar
NTRBL33
good advice
Old Apr 4, 2007 | 01:18 PM
XKR100's Avatar
XKR100
St. Jude Donor '08-'09
dlj
Davis,
The SOTP feel will be with a TQ converter but if he doesn't want that.Does he have to stay with the 2.73's?3.15 or 3.42's will even if he doesn't do anything else make it feel like a different car.Couple that with the TQ verter.It will be much better.The TR cam will be good,along with a good set of LT's.Tune is a must.jerry
Old Apr 4, 2007 | 01:29 PM
NTRBL33's Avatar
NTRBL33
Originally Posted by XKR100
Davis,
ya but this for Dave. Not sure if wants the TQ converter, will see.
you know how he is
Old Apr 4, 2007 | 01:52 PM
RED99's Avatar
RED99
He needs to dump the 2.73:1 gears before doing anything.
Old Apr 4, 2007 | 02:02 PM
pimpjames's Avatar
pimpjames
+1 There is NO better bang for the Buck on SOTP feeling IMO than Gears and a TC
Old Apr 4, 2007 | 02:19 PM
_Will_'s Avatar
_Will_
Torque converter nets most of the gains. Gears are good for .10 in 1/4, maybe .20
The Converter is what cuts 1/2 second or more. But gears will make the converter more drivable.
Old Apr 4, 2007 | 03:15 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Old Apr 4, 2007 | 06:09 PM
David426's Avatar
David426
3.73 gears and a 2800-3200 TC... 2.73's need to go.. Even if he descides on Headers,cam,heads... The 2.73 gears will still need to go
Old Apr 4, 2007 | 06:22 PM
cmeflibi's Avatar
cmeflibi
yeah agreed with everyone above...gears are a must...tell him to grab a used set out of a someone with a z06 that did the swap, you can get a decent price on one and it will make the car a whole new beast.
Old Apr 4, 2007 | 06:33 PM
slolane's Avatar
slolane
CI 7-8-9 Veteran
St. Jude Donor '07-'08 & '12
Get rid of the lame 2.73s You can not believe the difference in the car with gears and t/c
Old Apr 4, 2007 | 07:18 PM
DavzC5's Avatar
DavzC5
From: Houston, TX www.djmotorsportaccessories.com Specializing in C5 & C6 Accessories. DJ Motorsport Accessories.
Okay, Okay, Thanks, Davis. Headers, 2600 stall, 3:42 or 3:73 rear end is going in! I should've never taken you for a ride in my stock car!
Old Apr 4, 2007 | 07:48 PM
RED99's Avatar
RED99
Just replace the whole differential with anything that comes with at least 3.15:1 gears from the factory. It's suppose to be a stronger case. Even the 3.15:1 gears isn't a bad ratio, which is what my car came with as an option. If you want to take long drives, cruise on the highway, 3.42:1 would be an excellent choice for an A4.
Old Apr 4, 2007 | 08:28 PM
bcseitz's Avatar
bcseitz
My Vote:
First.....3.42"s and 2600-2800 TC That will give you more seat of pants then a H/C. (especially if you still had the 2.73's)
Second....Cam, valve springs, Harland Sharp kit to reinforce stock rockers, Hardened pushrods, Headers and a professional tune. (and also an improved air intake if you don't already have one)
PS. I'm running a Comp 222/224 566/568 112 on the stock converter. Idles at 750 with a nice lope. Works OK but boarderline, however my next mod will be a Vig. 2800.
To Need Some Power For An A4
Old Apr 4, 2007 | 08:36 PM
berryj's Avatar
berryj
Definitely the way to go. Worked wonders for me just w/ the 3.42 swap on my A4 vert. If I did it again, I'd definitely go w/ a converter. My 2.73 was soooooo lame. Drove like a lincoln when u floored it. After the 3.42 at least I could light the tires when she hit 2nd at full throttle.
Old Apr 5, 2007 | 07:15 AM
99 vett babycar's Avatar
99 vett babycar
Old Apr 5, 2007 | 07:17 AM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
TC, 3.42's and headers....thats all you need!
went from 13.2's to 11.8's with that along with a halltech SSM and a tune.
