Directional rotors
Old Apr 4, 2007 | 12:25 PM
edlipman's Avatar
edlipman
Default Directional rotors
Okay what is the CORRECT direction to install directional rotors ? ? ?
Baer says to install the rotors with the vanes pointing foward at the top.
GM and Coleman Racing products www.colemanracing.com and my logic says to install the rotors with the vanes pointing to the rear of the car to promote air flow thru the slots by centrifugal force.
I notice that GM puts only one directional rotor on the C6 Z06 , it points foward on one side and backward on the other side. Which is correct ? ? ?
I am looking for anyone who has a infra red temp gauge to check the rotor temps on both sides of the car after a few 60 mph to 15 mph stops the see which side has the cooler rotor and let the world know.
Who is correct ? ? ?
Baer says on their site that overheated rotors will not be elegible for warranty return. If Baer is giving the wrong direction to install their rotors who is at fault.
Ed
Old Apr 4, 2007 | 12:29 PM
AU N EGL's Avatar
AU N EGL
Colman is correct.
Direction of the vains is pointing backwards at the top of the rotor.
GM Bean counters only allowed one rotor for the front and rea.
For normal street braking it does not make much difference. But raceing it is like night and day for brake rotor cooling
60 to 15 mph stops wont show you much, but severl 100 to 20 mph stops will show you a lot.
Old Apr 4, 2007 | 12:31 PM
INTHERED's Avatar
INTHERED
You install all rotors per each manufacturers instructions. I used to think the same way until I called Baer and verified that their install instructions are correct. If you are racing I believe most guys use a solid Napa rotor because the drilled rotors will not hold up under racing conditions. I have drilled rotors but I put them on because they look cool.
Old Apr 4, 2007 | 01:19 PM
DRR's Avatar
DRR
Default Which Direction?
[QUOTE=INTHERED;1559669689]You install all rotors per each manufacturers instructions.QUOTE] I agree.
Is this right?
Or is this right? Correct Answer- Both.
When you get your new Bear Eradispeed Plus rotors, look at the vanes. You will notice that they flow from the center to the outside. In other words the outlets for the vanes point toward the back, not the front. The pattern of the holes and slots does not follow the vanes, but go the opposite direction on the Baer rotors.
Old Apr 4, 2007 | 02:15 PM
AU N EGL's Avatar
AU N EGL
The direction of the holes on the side of the rotors are not the direction of the veins.
Veins point backwards on TOP on the rotor
Old Apr 4, 2007 | 02:47 PM
DRR's Avatar
DRR
Here is a pic from the Baer site. Notice the holes and slots go the opposite direction from the vanes.
The instructions that come with them are clear as to which side of the car they go on. And they do not mount with vanes foward on top.
I don't know where you read that.
Old Apr 4, 2007 | 02:53 PM
LightFighter_GXP's Avatar
LightFighter_GXP
the cuts should chop into your breaks when spinning forward
Old Apr 4, 2007 | 03:24 PM
tiojames's Avatar
tiojames
When I spoke with Randy at Doug Rippie Motorsports I asked him which way the vents face. They face rearward to help the air introduced by the cooling vents to flow out thru the rotors easier, Normal driving probably not much difference, spirited driving in mountains or curvy roads will make a difference.
Old Apr 4, 2007 | 03:48 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
This is the right way!!!!
Randy
PS mount them wrong and you will have more heat into the wheel bearing too.
Old Apr 5, 2007 | 12:06 AM
gpracer1's Avatar
gpracer1
And some rotors have straight internal vanes, which have no specific direction.
Old Apr 5, 2007 | 08:23 AM
AU N EGL's Avatar
AU N EGL
Avoid those if you can. Much less cooling effect.
Old Apr 5, 2007 | 10:30 AM
robvuk's Avatar
robvuk
Ed
GM and countless others have already tested this. If it made one iota of a difference on the street, and that includes very "spirited" driving on any public roads, GM would have made them directional. But it doesn't. I have tried the temp gun on many cars at the HPDE events and I've never been able to confirm a difference that was consistent between cars that had both rotors and cars that had one. Now HPDE's are probably 100 times tougher on brakes than anything you can do on a public road. I think the difference of directional rotors will not show up unless you are doing more than 20 minute sessions in street cars. Just my observations with my temp gun and personal experience. Someone else may have more empirical evidence.
Old Apr 5, 2007 | 12:03 PM
edlipman's Avatar
edlipman
Yeah, my bad , I ASSumed the grooves in the rotors were in the same dir. as the vanes. I think I have it right now. The vanes SHOULD be pointing to the rear at the top.
I am still looking for some temp readings from someone out there.
Ed
Old Apr 5, 2007 | 12:36 PM
Mike Mercury's Avatar
Mike Mercury
remember, you are not looking at the holes or slots drilled into the outer surface; you're looking for the cooling vanes inbetween the outer rotor surfaces (the cutaway section in the pics).
Old Apr 5, 2007 | 01:40 PM
robvuk's Avatar
robvuk
Ed
Typically right off the track around 900 to 1200 depending on car and track. But this is after considerable time to cool off just driving into the pits. And as I stated, no significant or consistent difference between L & R.
Old Apr 5, 2007 | 01:52 PM
AU N EGL's Avatar
AU N EGL
Ed
Iron rotors glow oarnge at 1200*F
Carbon rotors glow orange white ~ 1400* F
WTF what temp is Over heating??
If your over heating your rotors, your not stopping and
Old Apr 5, 2007 | 04:50 PM
LoneStarFRC's Avatar
LoneStarFRC
I agree with most here on this. You cannot just use the direction of the slots (on the "firepath"), etc as the determining factor as to what is "right". In other words there is no "right" or "wrong". It depends on the manufacturer. As has been pointed out, Baer's Eradispeeds don't use a typical vane pattern. These should be installed as per Baer's recommendation.
HTH,
Robert
To Directional rotors
Old Apr 5, 2007 | 05:00 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
I put rotors on my car and put the wrong NAPA rotor on one side. Did I feel a difference at the track event driving not really. The thing that made me look was as I checked them after two session the backward one has significantly more heat checks after 2 or 3 sessions. It does make a difference. On the street you would be jailed before you could make a difference or your very lucky. Also the location you take rotor temps is very critical and it is cooler as you move toward the hub.
Old Apr 5, 2007 | 07:33 PM
robvuk's Avatar
robvuk
I have not even seen the difference in heat checks. I get both rotors heat checked in one day at Road America.
Old Apr 5, 2007 | 09:44 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
robvuk
That is because your are driving!!!!!!
