Pull Key and Wait 10 Seconds
Old Apr 4, 2007 | 06:24 PM
Bfail's Avatar
Bfail
Default Pull Key and Wait 10 Seconds
Why does this show up? It doesnt happen often, it seems after I wash my car it will do this. If I dont pull the key, it will die!
Old Apr 4, 2007 | 07:23 PM
DavzC5's Avatar
DavzC5
From: Houston, TX www.djmotorsportaccessories.com Specializing in C5 & C6 Accessories. DJ Motorsport Accessories.
St. Jude Donor '08-'09
Clean you key. Might just be the chip on it is too dirty.
Old Apr 4, 2007 | 09:01 PM
MNCrystalRed2011's Avatar
MNCrystalRed2011
Hopefully it is only the key that needs cleaning. Could be the onset of the dreaded column lock problem. If you have an automatic, the dealer will remove lock plate via a recall. Otherwise you should consider getting a Column Lock Bypass kit.
Old Apr 4, 2007 | 10:28 PM
tvlance's Avatar
tvlance
i've seen this "pull key, wait 10 seconds" message only briefly... and it was a time i was TRYING to start my car. i've had it for a month now ('02 z06), and it has an issue of not starting on occasion. it takes a while, lots of turning key and pushing clutch in and out, then itll finally start. ive been sitting in parking lots for a while on a few occasions trying to start the car. i have the GM certification warranty still, so the car is going to the dealership on friday. the service manager thought it could be related to the security system. the column lock recall has been done (can turn the wheel with the key out). ive been told by a few people on this forum to get a dealership to reverse the recall work, then install the CLB. that's the most rediculous thing. if a "recall" is done, that should fix it once and for all! silly to have to reverse it then install an aftermarket part. any thoughts? i'll try another key and clean the one i'm using.
Old Apr 4, 2007 | 10:36 PM
1999WHITEFRC's Avatar
1999WHITEFRC
oh no,mine did once this week....first time I seen it happen
Old Apr 4, 2007 | 10:41 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Read the Sticky at the top of this Tech forum on "Column Lock."
Old Apr 5, 2007 | 10:46 AM
Bfail's Avatar
Bfail
Thanks for the info ya'll
Old Apr 5, 2007 | 02:46 PM
HummelS's Avatar
HummelS
fwiw, this message is also displayed if you "false start" (turn key, engage starter briefly, but not start the car). If you turn the key again before the lock has time to reset, you'll get this message, because the computer doesn't "know" the position of the column lock.
Old Apr 17, 2007 | 11:08 PM
Wake Champ's Avatar
Wake Champ
Good info. I was curious because I have seen this message one time, when I turned the key on and off quickly. I was hoping it wasnt something major.
Old Apr 18, 2007 | 09:22 AM
Burgie's Avatar
Burgie
My 98 has done this when I started it quickly and immediately put it in gear to move the car. Shut it off, wait 10 sec and restart is fine. Same issue?
Old Apr 18, 2007 | 10:13 AM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
nothing like the column lock problem to ruin your day. check the saved thread at the top of the page to read details about this issue.
Old Apr 18, 2007 | 10:28 AM
Bfail's Avatar
Bfail
It doesnt seem like my column is locking up though my car is fully functional....It seems to only happen when it rains or after I wash my car....It rained in Dallas yesterday and it showed my that error twice and then the car dies. I pull the key, put it right back in and everything is gravy. I dont understand
Old Apr 18, 2007 | 11:37 AM
Icemanskis's Avatar
Icemanskis
St. Jude Donor '05
the same thing happened to me after i had the column lock recall done. i believe it turned out to be a broken relay that needed to be replaced. this should all be covered under the recall at the dealership.
Old Apr 18, 2007 | 12:36 PM
Bfail's Avatar
Bfail
Well my car is not under warrenty any longer. How much am I looking at spending on something like this? I have never had to take any care of mine in for a recall.
Old Apr 18, 2007 | 12:39 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
perfect, dont bring it to dealer. get the CLB. 49.00..end of worries forever
Old Apr 18, 2007 | 01:40 PM
Icemanskis's Avatar
Icemanskis
St. Jude Donor '05
depends on if it is a manual or an automatic. if it is an automatic, take it to the dealer, if manual get the column lock bypass. and it doesnt matter that the car is no longer under warranty. the recall still applies. does your steering wheel lock when you turn off the car?
Old Apr 18, 2007 | 03:53 PM
65GGvert's Avatar
65GGvert
Fill out your profile with your car specifics, it's a lot easier to help you knowing what you drive.
To Pull Key and Wait 10 Seconds
Old Apr 18, 2007 | 04:05 PM
bluvette79's Avatar
bluvette79
i have read the sticky and i bought the clb but since i have an a4 i am not sure i should install if the recall has been performed. i have never seen the message but i can hear the lock cylinder move when i turn on and off so i am thinking that maybe the recall has not been done. should i get the recall done with the a4 and then put on the clb or if the recall has not been done do you think the clb will solve the problem by itself. i really dont want them messing with my custom tune which is what i hear they do. also, with the clb on will i not have to worry about the fuel shut off which is part of the wait 10 sec. message (as i understand it)?
anybody but me confused?
Old Apr 18, 2007 | 04:14 PM
Icemanskis's Avatar
Icemanskis
St. Jude Donor '05
i also had the same problem with a custom tune. i have an auto. i took it to the dealer asked them to remove the locking plate and install the harness K as per the recall, but not to touch the PCM as I have a custom tune. They obliged and everything was fixed at no cost to me. I would suggest this route for an auto.
Old Apr 18, 2007 | 09:32 PM
bluvette79's Avatar
bluvette79
thanks. i guess i will take it too the dealer and cross my fingers.
thanks for the input. do you happen to know what software they need to change in the computer? wouldn't be the fuel shutoff by any chance?
